Boost pressure dropping off.
Old Sep 2, 2006 | 11:06 AM
crooksta's Avatar
Default Boost pressure dropping off.
My boost pressure on my a4 has recently started to drop off,it peaks on 20 psi and was holding on 18 psi,now it's only holding boost till about 4000 rpm,by 5000 rpm its dropped off to 10-12 psi,i have fitted a new air mass meter and also a new dump valve,it has been on vagcom and showing no faults,has anyone got any suggestions please,thanks.
Old Sep 2, 2006 | 02:20 PM
CO AVANT's Avatar
Default RE: Boost pressure dropping off.
k03/k04 turbos are not big enough to be pushing 20psi near redline. They run out of breath up top. A k03/k04 turbo will always start dropping boost around 4500rpms to redline. Should be ~12psi at redline. A good shifting point with those small turbos is ~5500rpms (where the torque and horsepower graphs cross each other pretty much).
Old Sep 2, 2006 | 04:51 PM
crooksta's Avatar
Thanks for the reply,so the drop in pressure is about right then,i thought this myself but i have been told by 2 garages it should hold its boost all the way,so i thought i'd better check this out.
Old Sep 2, 2006 | 05:57 PM
Jeff's Avatar
Zombie Defense Force
ya he is right. it will always fall off. thats the downside to a small turbo. you get quick spool but then it falls on its face
Old Sep 3, 2006 | 01:40 PM
david9999's Avatar
Time for a K04
Old Sep 4, 2006 | 04:11 PM
crooksta's Avatar
Thanks for the replys,also theres a fast tapping noise when you accelerate hard and turbo kicks in,thats what made me think there maybe a problem,but from what you say the turbo is working fine.
Old Sep 4, 2006 | 04:17 PM
CO AVANT's Avatar
prolly just the check valve by the airbox. If so, it's normal. Audi/VW sure likes to over-engineer their engines.
Old Sep 4, 2006 | 04:22 PM
Jeff's Avatar
ORIGINAL: CO AVANT
worthless cup holder[:@]
Old Sep 4, 2006 | 04:25 PM
crooksta's Avatar
Thanks,it does sound like its coming from that area,will the noise go if i replace the valve,its only recently started doing it.
Old Sep 4, 2006 | 04:43 PM
CO AVANT's Avatar
not sure, mine has been doing it since I got my K04 and raised my boost levels. (now have a GTRS)
