boost problem
Old Sep 18, 2006 | 05:51 PM
forcefedaudi's Avatar
Default boost problem
im making 4 lbs of boost,normally holds at about 15-16 and peaks at 21. 21-22 inches of mercury no codes no vacum leaks that i can hear of plus they would show up on the gauge. any help please
Old Sep 18, 2006 | 06:21 PM
socal_A4's Avatar
Default RE: boost problem
is your car in limp mode? I bet you have a leak around your dv area check it and then get back
Old Sep 18, 2006 | 06:24 PM
RLB6's Avatar
If your gauge checks out with no signs of leaks, then I'd say a leak around the DV too or even a faulty wastegate.
Old Sep 18, 2006 | 06:32 PM
socal_A4's Avatar
yea i was about to say that too^^^wastegate
Old Sep 18, 2006 | 07:25 PM
david9999's Avatar
Does the car feel like there is no boost? If it feels OK it is probably your gauge.
Are you sure there are not codes, or just no CEL.
I'd go for a bad diverter valve or wastegate, but there should be some codes stored with that.
Old Sep 18, 2006 | 09:31 PM
no cels ill scan it tomorrow and check if thers any codes. but the car is definetly not making boost i get passed by a honda on the cross island that shoudnt happen
Old Sep 18, 2006 | 09:41 PM
dafrazi's Avatar
Check your N75 connection. Pull the boot off the connector to check the wires too.
Old Sep 18, 2006 | 11:18 PM
david9999's Avatar
I would guess that you had an overboost situation and the car has gone into limp mode. Clearing the code will solve the problem
Old Sep 19, 2006 | 01:24 AM
would the over boost code cause a cel. replaced dv with the stock one that did nothing, really hoping its not the wastegate.
Old Sep 19, 2006 | 09:54 AM
david9999's Avatar
Overboost will not cause a CEL. It will however essentially shut off the turbo
audia4boy24
Jul 26, 2008 11:03 PM
dgirlsdemsugar
Jul 21, 2007 09:28 PM
eurotech
Apr 5, 2006 02:18 AM
Dieselboywu
Jul 24, 2005 02:11 PM
active1331
May 23, 2005 09:15 PM
