boost question
Old Feb 23, 2006 | 05:02 PM
bgolat's Avatar
Default boost question
I just installed my boost gauge last weekend. i have apr chip, and my boost seems to max out around 14-16, but it doesnt hold. say in second gear from a roll I floor it, it will go to full boost and as it is gaining speed & engine winds out the boost drops. i noticed on arifs video his stays solid on the bost until he lets of to **** etc. mine goes down pretty quickly, is this normal, or some kind of leak?
sorry i am turbo noob
Old Feb 23, 2006 | 05:07 PM
onepoint8tee's Avatar
Default RE: boost question
Well your k03 stock turbo wont hold boost near as well as any other turbo, especially arif's.. My giac chip holds 15-17 pretty good throughout the rpms until after about 5k rpm. Did you replace your diverter valve when you got the chip? Thats probably the problem if you havent replaced it.
Old Feb 23, 2006 | 05:26 PM
aRIf's Avatar
I think the reason is N75 valve. I do not use N75 b/c I have mbc. There was a guy test all this thing and N75 lower the boost in the higher rpms.
Old Feb 23, 2006 | 06:13 PM
brrman's Avatar
ORIGINAL: aRIf
On a k03 this is done for good reason. At a certain rpm point the k03 pushes nothing but hot air and would provide nothing extra anyway.
Old Feb 23, 2006 | 07:39 PM
bgolat's Avatar
oh ok thanks, then it is functioning correctly :P just wanted to make sure...
oooos4
Sep 6, 2014 11:28 PM
TTsteve
Oct 12, 2007 04:30 PM
TurboToughTT
Jul 28, 2007 10:49 PM
JohnnyBravoA4
Jan 2, 2007 05:02 PM
02tq
May 25, 2006 02:21 PM
