BOV vs. DV
Old Feb 7, 2006 | 05:06 PM
freeunit's Avatar
Default BOV vs. DV
I was wondering what is the difference between the two? also does the DV add performance.
thanks
side note how can you tell what year it is like a 99 or 99.5
Old Feb 7, 2006 | 05:09 PM
InsaneHatter's Avatar
Default RE: BOV vs. DV
This will tell you the difference in model years.
http://ctny.audiworld.com/mark/a4/diff/
You should use a DV (Diverter Valve) also known as a BPV (By Pass Valve)
Using a BOV in a non tuned setup will make you run rich and fowl plugs/cat.
There is no preformance difference to a BOV/DV only the sound. A DV is quieter.
Old Feb 7, 2006 | 05:10 PM
freeunit's Avatar
do you still get a cool sound out of the DV?
18T's Avatar
18T
I know you are new, but use the search function next time. this is discussed 100 times a month
here is a helpfull post about DV and BOV
https://www.audiforums.com/m_14128/tm.htm
