Brake fluid reservoir
Old Jan 3, 2007 | 11:59 AM
bixing's Avatar
Default RE: Brake fluid reservoir
WOW! So I dont need to probably change the chamber,.. just sealing is fine if the crack isnt too big!
Old Jan 3, 2007 | 08:46 PM
bixing's Avatar
Hey guys.. Finally, somebody helped me to check the code... He said that the water temperature sensor is going down (which he explained is likely to be due to low weather temp in nights in winter)....
Now, if someone could let me know where it is located and where to buy it from?
(Also, he said that its near the coolant as if he'll have to replace it, some of the coolant might drain out)
Thanx before hand..
Old Jan 3, 2007 | 10:20 PM
Trey25's Avatar
Hmm...can't see how that explains the coolant temp gauge going down, once the engine is warm the temp stays in the middle regardless of outside temp. But anyways here..
http://www.audiworld.com/tech/eng54.shtml
http://www.audiworld.com/tech/eng66.shtml
You won't be spilling much coolant so don't worry.
Old Jan 5, 2007 | 05:09 PM
bixing's Avatar
Hey thanx Trey25
I ll try sort it out in couple of weeks now once I get my sensor
Enjoy
Old Jan 11, 2007 | 10:14 PM
bixing's Avatar
Okkk.. NOW.. This god domn car is showing attitude...
Its driving fine.. witht he temp gauze fluctuating b/w minimum and center. BUT at times it doesnt start..[:@]
Wat I mean is that I have to crack it about 5-6 times before it starts again.. It has done this 3 times now.. the last 2 being within a span of 2 days.
Wat do you guys think? Is it just the sensor that demands urgent attention or something else is brewing up???
Please help!
Thanks
Bix
Old Jan 11, 2007 | 10:57 PM
Trey25's Avatar
Is it cold where you live?
Old Jan 11, 2007 | 11:13 PM
bixing's Avatar
I live in Durham, NC. I can't quantify cold but I can tell u the weather here.
It fluctuates from 30 to 70 these days.. last 2 days, it has been 30.
the thing is that my car starts perfectly in morning.. but lets say i went to the mall in evening.. and parked for 30-60 min. and came back and then it would cause problems.. I dont think it ll go cold so fast or anything like that??
Wat do u say?
Old Jan 11, 2007 | 11:18 PM
  #18
theguy1084's Avatar
Whats up with this stealership S***. If you think they are steeling your money just go to joe shmo down the road Im sure they know what they are doing
Old Jan 11, 2007 | 11:38 PM
  #19
bixing's Avatar
Well, first thing I am gonna change the sensor once my order arrives,... Then I'll c if it behaves the same, I'll go to a decent mechanic but ofcourse not stealership
Thanx
Old Jan 12, 2007 | 12:17 AM
  #20
theguy1084's Avatar
but you will go somewhere and pay for the knowledge that you dont know and that only a dealership knows...its a business
