brake pad sensor question
Old Dec 19, 2007 | 08:57 AM
ddd's Avatar
ddd
Default brake pad sensor question
hey, I bought a set of front and rear brake pads(without sensors) for for my 2000 A4 a few months ago for spare backup. I recently found out that my current pads do have sensors. When my current pads need changing, can I use the spare one that I have in stock. Would there be problems warning sensors lighting up?
Old Dec 19, 2007 | 09:44 AM
Papachristou's Avatar
Default RE: brake pad sensor question
you just need to loop the sensor... most people who use better pads have to do this.. you just wire it in a loop so it fools the sensor....
there really isnt a sensor but a metal contact on the pad that makes an electrical loop and when the pad wears low, it breaks the connection triggering the "sensor"
Old Dec 19, 2007 | 09:52 AM
dafowler88's Avatar
I just left the sensors unplugged, the light didn't illuminate
Old Dec 19, 2007 | 11:25 AM
hiwords's Avatar
cut the wires on your old pads, splice those 2 wires together and plug it into the harness on the car and you'll be all good.
Old Dec 19, 2007 | 11:39 AM
ddd's Avatar
ddd
thanks guys
Old Dec 19, 2007 | 11:40 AM
techbod's Avatar
[:-]that will make the light come on ( break pad wear indicator has a plastic cap and when they wear down the cap is obliterated and continuity is seen by the wires making a circuit which puts the light on ) mind you im an old fart so things might have changed
Old Dec 19, 2007 | 11:41 AM
hiwords's Avatar
well it's what i did on my b5. when i didn't do that, the light was on.
Old Dec 19, 2007 | 06:07 PM
CRAZYHAWK's Avatar
hiwords is correct. I put an ohm meter across the connectors
on my new pads. It read 0 ohms.
Old Dec 19, 2007 | 06:20 PM
tHe kNiGHt FaLL's Avatar
the light comes on when there is an open in the circuit.
since you do not have pad wires... all you do is take a staple, bend it in a 'U' and insert it in the 2 pinson the connector and wrap tape around it.
01quattro
Aug 31, 2014 12:36 PM
djMichaels
Jun 23, 2011 09:34 PM
whatisthat
Apr 12, 2011 11:53 AM
patekatek
Jan 13, 2008 02:10 PM
bftlg
Jan 20, 2007 06:34 PM
