BRAKE PAD WARNING INDICATOR
Old Nov 12, 2004 | 09:23 PM
CRAZYHAWK's Avatar
Default BRAKE PAD WARNING INDICATOR
The circle with brake shoes on the outside keeps appearing. It happens every 4 or 5 days. If I shut the engine off and restart, the indictor resets. I have 3/8" on the front pads and at least an 1/8" on th rear. Any suggestions.
Old Nov 12, 2004 | 09:30 PM
Jestnomen's Avatar
6th Gear
Default RE: BRAKE PAD WARNING INDICATOR
umm, don't you think 1/8" is kind of worn down? Time for new pads.
Old Nov 12, 2004 | 10:00 PM
Auditwins's Avatar
Have the brake fluid checked. If the pads are worn it could need more brake fluid. sometimes it is just enough to trigger the sensor.
Old Nov 12, 2004 | 10:45 PM
David_K's Avatar
hmmm... a lack of brake fluid would cauze a huge increase in stopping distance. I dont think it would effect the brake pads. In fact it would actually make the pads last longer because they are not being pressed against the rotor as hard.
Old Nov 12, 2004 | 11:16 PM
Jestnomen's Avatar
6th Gear
The only way you would have a increase of stopping distance is if you were missing a large amount of fluid. Well beyond the sensor level. The pads are still going to press the same against the rotors, you would just have to press the pedel harder to build enough pressure.
Old Nov 12, 2004 | 11:41 PM
David_K's Avatar
hmmmmm
Old Nov 13, 2004 | 12:53 AM
CRAZYHAWK's Avatar
I have 72Kmi now. The dealer gave me new pads at 50Kmi.
Brake fluid is full. Chilton manual says rear minimum is 5/64".
If a sensor was faulty, how could I check it out?
Old Nov 13, 2004 | 02:09 AM
Jestnomen's Avatar
6th Gear
There really isnt s "sensor" exactly. There is just a wire that runs through the pads and when they get worn down the conection is lost. I suppose you could pull off the connector and jumper the two leads together to see if the light extinguishes.
Old Nov 13, 2004 | 05:04 AM
sfordeso's Avatar
I would have to agree with Jared at the start of this thread (to answer the question at hand) 1/8 is kinda low, this is prolly what the light is all about.
Old Nov 13, 2004 | 11:14 AM
CRAZYHAWK's Avatar
I thought a conection was made when the pads are warn. I'll have my mechanic change the rear on Tuesday. Thanks
