Brake Pulse
Old Apr 23, 2005 | 10:04 PM
jsatterf's Avatar
Default Brake Pulse
Looking for info.
Just got a 98 A4 1.8T Quattro with 89K miles. When I apply the brakes easy, there is a pulse coming back through the pedal. If I brake firm its not there, is this normal?
Old Apr 23, 2005 | 10:34 PM
Shaunp05's Avatar
Default RE: Brake Pulse
nope you have some bad rotors
Can you feel where its coming from
Front or rear ?
If you cant tell drive on road that is not busy
and very little apply you hand brake, NOT MUCH !!!!
and see if you can feel the pulse through the body or Brake handle
Old Apr 23, 2005 | 10:35 PM
Jestnomen's Avatar
6th Gear
agree, sounds like warped rotors to me.
Old Apr 24, 2005 | 01:31 AM
Nasty's Avatar
ive got the same problem
Old Apr 24, 2005 | 10:32 AM
david9999's Avatar
Warped rotors. Either that, or you have uneven deposits of pad material on the rotors.
Check ecstuning.com for reasonably priced replacements.
Old Apr 26, 2005 | 08:33 PM
Nasty's Avatar
i went to be my breaks checked out today and i guess there is nothing wrong with them, 50% left on the front and 25% on the back. i guess ill just have to deal with the pulse
Old Apr 26, 2005 | 08:46 PM
headshok2002's Avatar
doesnt matter what % is left on your brakes bud, if they are warped, they are warped... I could show you brakes with 99% left, that are warped to hell. They get warped when they experience insane heat, from continous long hard stops. You're car may have had the snot driven it out of it
But yeah, that is the principle behind drilled/slotted rotors... get rid of heat, to avoid brake-fade and warped rotors.
Old Apr 27, 2005 | 03:55 AM
Aliel's Avatar
Might even be a bad ABS sensor. I had a vibration only when I stepped on the brake doing low speeds and I turned out to be a bad ABS sensor.
Old Apr 28, 2005 | 12:45 AM
jsatterf's Avatar
The pulse I am feeling doesn't seem like its warped rotors, I've had that in other cars and the vibration was felt throughout braking.
This pulse does not occur until the last few feet of stopping, and it feels like ABS feed back. Very similar to when stopping on ice and pedal pulses as the wheels grip. I've tried braking with the hand brake and don't feel it.
Is there anywhere to check the ABS sensor so simply replace it?
I appreciate all the feedback.
Old Apr 28, 2005 | 12:53 AM
BFlan2001's Avatar
that is def your abs sensor, you have to remove your wheel, and it will be right there behind it. many times they just aren't installed correctly..like if someone has recently done any suspension work, they may have reinstalled it wrong...that would be ideal, since a new one is about 140 bucks [sm=icon_quiet.gif]
