Brake warning light beeping and ESP on
Old Mar 11, 2018 | 10:10 AM
Arin's Avatar
Default Brake warning light beeping and ESP on
I have an A4 2L tdi 2006, this morning when I switched on the engine came on the red warning light brake on and off beeping and after few minutes of drive the ESP came on aswell and it stays on even if I turn the engine off and back on. Checked the brake fluid and its almost max. Can someone help me please.
Old Mar 12, 2018 | 09:27 AM
rhodes991's Avatar
If possible pull any error codes. Generally this light is tied to a failure in the traction control system or ABS. Could be just a faulty sensor, but without more information you probably will need to have a shop take a look.
Old Mar 12, 2018 | 09:33 AM
Arin's Avatar
Thanks for the reply, the brake warning light turned off later on, only the ESP stays on non-stop but I will go to plug the car and clear the faults. Probably it was a sensor.
MagsA3
Apr 29, 2021 10:33 PM
cipi888
Jul 16, 2013 05:11 PM
Audiman08
Apr 11, 2009 08:13 PM
707782y
Dec 2, 2006 05:42 PM
skibum0019
Oct 5, 2004 01:38 PM
