Brake warning light when accelerating
Old Aug 2, 2007 | 02:29 PM
drp1489's Avatar
Default Brake warning light when accelerating
i've noticed lately that the brake warning light in the dash, the red one that says BRAKE comes on and blinks when i accelerate fast and let the revs go up a little further before i shift. like i'll be at a light and take off and after i hit like 6000rpm and shift it comes on. \
anybody know whats going on? is it a safety feature maybe?
thanks in advance
Old Aug 2, 2007 | 02:31 PM
wood_e's Avatar
Default RE: Brake warning light when accelerating
Low fluid level?
Old Aug 2, 2007 | 08:18 PM
drp1489's Avatar
i thought that but wouldn't it go on more often? it only comes on when i accelerate fast and let it redline. i'll keep searching
Old Aug 2, 2007 | 08:22 PM
A4Rollin's Avatar
my friend had this before on his car and turned out the parking break was loose (in the back) and would move around when he accelerated causing the light to come on
[/align]
Old Aug 2, 2007 | 08:25 PM
18T's Avatar
18T
top off your brake fluid and see if it goes away. it should.
Old Aug 2, 2007 | 08:28 PM
a4aaron's Avatar
as previously posted...definately a fluid level issue
Old Aug 2, 2007 | 08:38 PM
AteUrV8's Avatar
either a fluid problem or the ABS sensor is coming loose when the car is jolting forward from the shift, this is what happened to me.
Old Aug 2, 2007 | 09:32 PM
drp1489's Avatar
ok thanks. any way to check the sensor that might be coming loose?
Old Sep 28, 2007 | 08:40 PM
drp1489's Avatar
anybody know where the sensor is and how to check it?
thanks
Old Sep 28, 2007 | 08:46 PM
cincyTT's Avatar
I'm make believe
why? its just low brake fluid like you have been told 4 times
