Brakes
Old Nov 1, 2005 | 10:57 PM
slimmj0k3r's Avatar
Default Brakes
OK, so whenever i'm braking and turning to the right, i get this high pitched squeak, im almost 100% sure its from the brakes, because everything else seems to be fine. So im gonna check em out, probally my pads are worn out. ANyone know anyplace to get new brake pads??? or any good reccomendations
Old Nov 1, 2005 | 11:04 PM
BadLuckAudi's Avatar
Default RE: Brakes
Your local auto store should carry them and they should only be about $20.
Old Nov 1, 2005 | 11:44 PM
drkenan's Avatar
Default RE: Brakes
If it's your rear brakes and you pull the rotors MAKE SURE that you have the caliper retraction tool!!!!!! I just did mine last weekend and had to put the old brake pads back on b/c I couldn't get my calipers retracted (believe me I tried for hours and hours with needlenose pliers and some other "brake cube" tool that they sell at autozone). Speaking of which I have no idea why I haven't ordered that freakin' tool yet....
Old Nov 2, 2005 | 12:55 AM
afruss2007's Avatar
Default RE: Brakes
Does the Autozone tool not work? I got that and haven't used it yet.
Old Nov 2, 2005 | 03:18 AM
fritz's Avatar
Default RE: Brakes
I used the brake piston pusher from autozone and it worked fine. changing the brakes on the back is fairly simple, hardest part is turning the piston pusher...
Old Nov 2, 2005 | 03:30 AM
flyboy's Avatar
Default RE: Brakes
I remember my moms old lumina had that same crap on hers and I turned and pushed and pushed and turned and nothing, so I just pressed them back into the caliper and she didn't have e-brake after that.
Old Nov 2, 2005 | 03:44 AM
fritz's Avatar
Default RE: Brakes
lol
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
