Brakes
Old Mar 8, 2005 | 04:21 PM
Jeff's Avatar
Zombie Defense Force
Default Brakes
I just took my car to audi to have the 50000 mile check up and they told me that my front suspension is broke on the left and the right and i need to replace my brakes. i have 15 inch rims and was wondering what r the largest brakes that i can put on my car. also if i got 17 inch rims what brakes would you recomend?
Old Mar 8, 2005 | 04:26 PM
audihere's Avatar
Banned
Default RE: Brakes
depends on what u wanna spend they have the porshe upgrades...pretty sweet
Old Mar 8, 2005 | 05:00 PM
clconversion's Avatar
Default RE: Brakes
but u will need bigger rims for sure if you want to do a big brake upgrade you could just get slotted rotors if you like that are the same size as what u have now but being slotted they will disapeat heat better than stock and they will fit behind your stock 15" wheels
Old Mar 8, 2005 | 06:04 PM
Jeff's Avatar
Default RE: Brakes
could i get new calipers or would i also need larger rims. i want to look at the best roters/calipers that i can get
Old Mar 8, 2005 | 06:32 PM
Default RE: Brakes
if you are looking at new calipers u are probley looking at a big brake kit and you will need to change your wheels for that
Old Mar 9, 2005 | 03:17 AM
Covz's Avatar
Default RE: Brakes
get Brembro, best brake kits u can buy!!!! there about 2500!
Old Mar 9, 2005 | 03:22 AM
Jeff's Avatar
Default RE: Brakes
slotted or cross drilled
Old Mar 9, 2005 | 03:26 AM
Covz's Avatar
Default RE: Brakes
Both. I wanted to go with the brembros but i want to save up for other mods so im just cleaning up the stock calipers really nice and putting some high gloss black paint on it, i bought drilled and slotted rotors, stainless steal brake lines and pads..
Old Mar 9, 2005 | 03:53 PM
Jeff's Avatar
Default RE: Brakes
does brembo or stop tec make oem slotter and cross drilled roters?
Old Mar 10, 2005 | 01:06 AM
david9999's Avatar
Default RE: Brakes
Unless you are doing some heavy duty braking, why do you need slotted rotors. They certainly are going to shorten your pad life a lot more than they will shorten your stopping distance
