Brakes have gone
Old Jun 4, 2005 | 06:12 AM
apg96's Avatar
Default Brakes have gone
I havent checked them yet but i know i need some new ones. What are teh good pads that everyone likes? I like the ceramics ones that will give me more "bite" and teh ones with "less dust" or dif. color dust. What specal tools will i need to do it myself? Caliper compresser?
Old Jun 4, 2005 | 01:21 PM
hb972.8q's Avatar
Default RE: Brakes have gone
i have ebc green stuff on right now. other people have mintex reds i forget other names right now. to change the front pads all you need is a big c-clamp. the rear i would go out and buy the tool needed they have it at ecs rear brake caliper tool
Old Jun 4, 2005 | 01:36 PM
juju4uofa's Avatar
I'm curious myself which pads to go with next. I recently changed mine but I just went with cheap pads from autozone because I'm broke. hb972.8q was right, all you need for the front calipers is a c-clamp. The piston simply compresses in without twisting. However, for the rear calipers you either need the speacial tool or, I used needle nosed pliers. I'm sure the tool would have been easier because you have to press in on the caliper while twisting which was difficuly to do with the pliers. If you don't already have one I recommend getting a Hayne's repair manual for your car. It'll tell you exactly how to change your pads. Good luck!
Old Jun 4, 2005 | 03:44 PM
a4autocrossr's Avatar
Ferodo's are sick...im getting a set soon...my pads are S2S (shot to ****)
--E
Old Jun 4, 2005 | 05:45 PM
apg96's Avatar
i have the manual. I will look at that tool. Atautocross where can i find those pads? Are ceramics worth the extra money? I am looking at the Hawk Performance pads that are ceramic (94.95 for a set of 4)
Old Jun 4, 2005 | 10:33 PM
apg96's Avatar
So i checked my pads and they actually look new and have plenty of pad left. I also checked the brake fluid and that was fine. So what shopuld i have checked. I know something is wrong becuase it was making this horrible sound when stopping. Yesterday i was in Laguna Beach and my friend lives up in the huge hills and when i was going down the steep *** hil they were making sounds that i have never heard before.
Old Jun 4, 2005 | 10:42 PM
headshok2002's Avatar
If you were doing lots of hard or long stops... they might have just gotten really hot. They can start to make some noise then...
no pulsation in the pedal when you brake? Lots of people warp their rotors, braking more aggressivly than stock brakes can handle.
Old Jun 4, 2005 | 10:49 PM
apg96's Avatar
yes there was a little but but i have gone down that many of times and they have never been like that, They also sound pretty bad going down PCH on the way there and that is just a normal highway.
Old Jun 4, 2005 | 11:05 PM
david9999's Avatar
Where is the noise coming from?
If the pads are good then there shouldn't be any grinding unless something got caught behind the pad (highly unlikely)
If you havent driven in a day or two (esp if you are in a damp climate) you may get some grinding the first time you use your brakes as the rotors will slightly rust.
Do you get noise without applying the brakes? Could be that one of the calipers is seized and not retracting.
Old Jun 4, 2005 | 11:14 PM
apg96's Avatar
I have been driving my car evryday day, except today b/c i didnt want to until i checked teh pads. There is sometimes a slight squeaking when driving at slow speeds. it may not be noticable at higher speeds since the wind noise may block teh sound. It is teh loudest when i am braking hard, instead of braking and downshifting like i would when i stop at a red light. it is most obvious whne i stop quick for a changing light or someone in front of me or soemthing like that.
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
