braking problem--help
Old Feb 15, 2006 | 01:17 PM
ganicki344i's Avatar
Default braking problem--help
Just bought a A4 2.8 quattro-- every time I start to slow down on wet or dry just before a complete stop -- it feels like the ABS is going off(slightly) anyone have any idea what this could be?-- was happening before and after new pads-- haven't changed out brake fluid thats the next step. Is it something common to Audis has this happened to anyone else.-- Thanks
Old Feb 15, 2006 | 01:22 PM
miabhai_freaked's Avatar
Default RE: braking problem--help
Good point mate...that happened to me a couple of times as well.
Don't know what's up with that. I went to my mechanic, he tells
me he doesn't see anything wrong!
Old Feb 15, 2006 | 01:23 PM
Deke's Avatar
Sounds like warped rotors to me. The harder you push the brake pedal the more pronounced it feels right?
Old Feb 15, 2006 | 01:27 PM
onepoint8tee's Avatar
check/clean your abs sensors
Old Feb 15, 2006 | 01:30 PM
ORIGINAL: Deke
Hmmm...it DOES seem somewhat jumpy though...if you know what I mean...
Also, I just realized that it does one more thing as well. When I brake, it seems
to get stuck in the brake position for a second or 2 and then jumps and releases.
I'm having all kind of trouble with this car!!
DRIVING ME NUTTTTTTTTTTS
Old Feb 15, 2006 | 01:33 PM
avanttripleloop's Avatar
that could happen with air in the line.have them flushed
Old Feb 15, 2006 | 01:41 PM
Any pointers on how to check/clean my ABS sensors?
GraffixWB's Avatar
rear wheel speed sensors need replaced. 100% . had it happen twice on my car. well, most likely rear
Old Feb 15, 2006 | 01:43 PM
ORIGINAL: Deke
Not really, the harder i push the less of a chance that it happens-- theres no other pedal modulation other than the ABS feel, and no steering wheel shake-- I'm Stumped-- guess I'll do the fluid change and sensor cleaning. Any other suggestions?
Old Feb 15, 2006 | 01:53 PM
GraffixWB's Avatar
READ ABOVE!! THAT'S WHAT IT IS
