Brand New VVME HID kit in box 4300k $70 + Shipping
Old Nov 20, 2007 | 07:58 PM
AudiOso's Avatar
Default Brand New VVME HID kit in box 4300k $70 + Shipping
I just got my kit today, and I just am not feeling it. I don't see where this is going install properly. I think I'm going to go used OEM instead. I want a setup that is truly plug and play. PM me for details.
Old Nov 20, 2007 | 08:03 PM
onepoint8tee's Avatar
Default RE: Brand New VVME HID kit in box 4300k $70 + Shipping
Why wouldnt it install properly?I/others have not had anyissues. How is it not plug n play? All you have to do is mount the ballasts somehwere, like under the headlights.
hiwords's Avatar
it should be plug and play though. wut part do u see that isn't?
Old Nov 20, 2007 | 08:08 PM
AudiOso's Avatar
I have a B6 and the ballasts will not fit properly under the headlamp units like they do on the B5 cars. I am just going on what I have read here on the forum. I wish I had thought this through before ordering the kit, but hey, my mistake is someone else's gain since the kit shipped to the US is $90. I will just drop the coin on a set of OEM units. I want a setup that drops right in without any modification.
Old Nov 20, 2007 | 08:13 PM
hiwords's Avatar
it should fit. if u don't want to drill u can always ziptip them. that's actually wut im going to do when i get mine. does ur S4 have HIDs? if it does u can always do it that way or u can go to the dealership and pretend like ur interested and ask them to pop the hood lol.
Old Nov 20, 2007 | 09:03 PM
AudiOso's Avatar
My S4 and my TT both have the factory HID setup. I've had the lamps out on my S4. I had to change a turn signal bulb. The factory ballasts are thinner and seal to the bottom of the headlamp assembly. This kit is nice, but I just don't see where the ballasts can go. They are too thick to mount to the bottom of the headlamp assemblies. I will pull the driver's side Thursday morning if the weather permits and see if there is anyplace to mount the ballasts other than below the headlamp.
Old Nov 20, 2007 | 10:04 PM
ocadam's Avatar
You can mount them anywhere. Its probably one of the easiest things to do easier than wiping your butt.
Old Nov 22, 2007 | 09:37 AM
AudiOso's Avatar
Where do you ground the f*cking things then?
Old Nov 22, 2007 | 09:54 AM
hiwords's Avatar
u have to ground stuff? well u can ground it on anywhere on the body. just drill a hole and ground it. i believe the engine has a couple ground points but don't drill the engine lol
Old Nov 22, 2007 | 10:08 AM
ImTheDevil's Avatar
The grounding is all built into the harnesses - there aren't any external grounds to attach. Just find a location such as an existing bolt on each side of the engine bay, near the headlights, and use those to mount the ballasts.
