Breather tube crack
Old Mar 2, 2007 | 07:28 PM
home4sale2's Avatar
Default RE: Breather tube crack
Thanks all. Pilot, I was told by the dealer that unless I replaced mine, I "might" get a CEL (had my head scratching for a minute, you mean Check engine light).
oh1a4, checked out websites you recommended. Zimmerman seems to only show up for front rotors ($50 like you said). The only rear ones I see are ATE ($26.95) and they seem to be smaller size. Are the rear ones smaller because it's a FWD (I don't have a Quattro)?I wouldn't want to do the brake job myself but was thinking to take it to a local mechanic at the Shell station, Midas? I imagine the Mintex brake pads are good too.
Also, there is only one breather tube in this car, right? Does anyone have any pics of where it is. Thx.
Old Mar 2, 2007 | 08:17 PM
oh1a4's Avatar
sorry, didnt realize it was rear rotors, but yes, all ofour oem b5 a4rear rotors are smaller, regardless of fwd/q. there are upgrade options for the rear as well (such as A6 255mm rotors or A8 269mm rotors) but you will have to mod the caliper carrier (front kits come with TT carriers and fit without grinding.)
ate is fine too.
if you really like the look of slotted rotors, blauparts has a niceorbital slottedrotors, front and rear(they have plain ones too, which i recommend sticking with, but thats just me.)
sorry for the thread jack since this was originally about breathers, just trying to help.
Old May 30, 2007 | 12:52 PM
dxl2749's Avatar
Hi guys I'm about to replace mine too but i have no idea how to get to it....i spent 1 hour just trying to get the nub of the old breather hose off my crankcase and all i have is lots of bruises on my knuckles....is there any way of taking it off without taking off the intake manifold and could someone spell it out for me?
Thanks
David
[IMG]local://upfiles/26216/B1BAD4A63CCA4E66B75EFF2618536DFC.gif[/IMG]
Old May 30, 2007 | 02:46 PM
Audi A Fizzle's Avatar
i replaced that same hose, but i still get the system lean CEL.
and for some reason i could not get it extremely tight, its somehwat loose in their to a small degree. . . ?
Old May 30, 2007 | 03:52 PM
dxl2749's Avatar
when you replaced the hose how did you get to it? Did you have to take of the intake manifold?
Old May 30, 2007 | 04:13 PM
no it was not fun thought, you will scratch up your knuckles a little bit.
i took off a few hoses and removed the collant overflow tank though, seemed to be the only way i could get access to it
Old May 30, 2007 | 06:18 PM
dxl2749's Avatar
thanks man....going to try it tonight after work....is the cel you are getting 16795 for secondary air injection? if it is you might need a new secondary air injection pump (smog pump at discount auto parts) and a pcv valve.....they seem to be problems with mine that i hope will go away once i fix the hose and replace the pump and valve.
Old May 30, 2007 | 06:29 PM
  #18
let me know how it goes man, mines a bit loose still
Old May 30, 2007 | 06:41 PM
  #19
TDRILL's Avatar
I broke mine when I did my sparkplugs. Its right in the way and its almost like they put it there so that you would break it when the end of the sparkplug wire comes off. For the V6 that stupid hose is like $75 on ECS.
I just got some shrink tubing, slid 3 separate peices up the tube and then slid them back down over the crack one at a time and heated them up. It makes a pretty good seal, cost me almost nothing (if you have a heat gun or go ghetto and just use a lighter), and was a lot easier than replacing the whole hose. It stronger than the original hose was too. Think about giving this a try. That hose is just a breather hose, not like it is pulling or pushing air around. Very, very little actually moves through it. Its a little ghetto, but much better than using tape etc.
Jerry Rigging by TDRILL.
See also:The many uses for zip ties.
Old May 30, 2007 | 09:14 PM
  #20
akielb's Avatar
I just checked mine out and what do ya know - its split in one part and cut in two in another. Guess I'll be doin this job too - please post how you did it.
