A/C Evap Question
Old Aug 22, 2007 | 02:52 PM
19audia496's Avatar
Default A/C Evap Question
I'm about to replace my A/C evaporator, i have the dash off, anything i need to know before unhooking it and replacing it? It has no freon and is discharged already... anything else??
Old Aug 22, 2007 | 04:11 PM
auditech79's Avatar
Default RE: A/C Evap Question
Just don't rip the rubber seal that sits around the evaporator inside the case. You don't get a new one with a new evaporator.
Old Aug 22, 2007 | 05:17 PM
19audia496's Avatar
Can you please be a little bit more specific, i really don't want to screw this up... I will be changing it 2morrow... The rubber seal you speak of, is it part of the evaporator or part of the black casing around it? Thanks for all your help...
p.s. my car sure does look funny without a dash, I have been driving to work in back with my instrument cluster sitting on top of my steering wheel. I have to laugh at myself at timeshaha
Old Aug 22, 2007 | 05:32 PM
auditech79's Avatar
Yeah its a big black rubber strap that is streched around the evaporator, Its pretty thick so its not very easy to rip it, its just there to insulate the evaporator so it cools effenciently, if you ripped it or forget to put it back in the cooling wouldn't be very good.
Old Aug 23, 2007 | 04:40 PM
19audia496's Avatar
Okay, i have removed it and everything off... there is no black rubber around the evaporator (which maybe is why it went bad)... what could i warp it up with to keep it cold and protected?? any ideas?? also, do i need to replace all the o-rings?? or just the ones that were taken out??
Old Aug 23, 2007 | 04:54 PM
techbod's Avatar
Dismantling and assembling air conditioner - vehicles up to Model Year 1996[/align]Disassembling and assembling evaporator housing[/align]
‒Dismantle the air conditioner
[ul][/ul]
1. Intake
â—†With air-flow flap
â—†Removing and installing air flow flap
â—†Before assembly, coat the sealing surfaces to the top half of housing with silicone rubber.
[ul][/ul]
2. Vacuum unit for fresh-air and recirculated-air flap
[ul][/ul]
3. Upper section of housing
[ul][/ul]
4. Gasket
â—†Glued into the top half of the evaporator housing
[ul][/ul]
5. Evaporator
6. Bracket
â—†Prise off using a screwdriver
[ul][/ul]
7. Intake ring
â—†Secured by a cast pin to the lower half of the housing to prevent turning
[ul][/ul]
8. Bottom part of housing
[ul][/ul]
9. Fresh-air blower -V2
[ul][/ul]
[ul][/ul]
[IMG]local://upfiles/12092/57B4E020A9C64F7FA4365FE345BF088A.jpg[/IMG]
Old Aug 23, 2007 | 05:32 PM
19audia496's Avatar
Thanks for the diagram, but it didn't really answer my question that much. I guess I will get this figured out somehow. Tomorrow is the big day for the project, putting it back together and putting the entire dash back. Tidious work, but I think I will enjoy it. ha.
Old Aug 23, 2007 | 05:34 PM
auditech79's Avatar
Replace any o-rings you find, especially the ones at the bulkhead between the engine compartment and the inside of the vehicle. I would try and use some type of insulating wrap from home depot or something. to help keep it cool.
MyFreeAudi
Nov 2, 2014 04:05 PM
lolo22
Aug 13, 2013 06:14 PM
lyosha
Aug 29, 2011 12:09 AM
aublutiger
B7 Models
Aug 23, 2010 03:24 PM
SrK
Apr 24, 2008 02:16 PM
