A/C Evaporator replacement, should I?
Old May 19, 2006 | 03:18 PM
gregp1962's Avatar
Default A/C Evaporator replacement, should I?
I've been dreading this. My evaporator seems to need to be replaced. I'm deciding if I should do it myself. I was doubtful if I should do the turbo myself. I decided to do it and it all worked out well.
Who has done the evaporator? Would you do it again?
Old May 19, 2006 | 03:31 PM
techbod's Avatar
Default RE: A/C Evaporator replacement, should I?
quite a simple job apart from the gasses and oil mix loss and you have to get it re-gassed but if you can do it you will save a lot of cash
Old May 19, 2006 | 03:38 PM
gregp1962's Avatar
Well, that's the first time I've heard that it is a simple job to replace. Everyone talks about what a pain it is.
Old May 19, 2006 | 03:43 PM
techbod's Avatar
very simple job mate, we love to hate jobs you know because its the timing belt where most people have to go in and your problem is at the front
Old May 19, 2006 | 03:45 PM
techbod's Avatar
bumper off and wamy your there
Old May 19, 2006 | 03:58 PM
techbod's Avatar
oh **** I was thinking condenser silly me[:@] so it will be a big job dash out thing
Old May 19, 2006 | 05:16 PM
gregp1962's Avatar
I'm hoping someone here will be encouraging to do it. Has anyone done it and found it simple?
Old May 20, 2006 | 02:22 PM
dankhound's Avatar
Newer done one but working under the dash of an audi is a pain in the ***. Its definatly not a simple job. What makes you think you need a new evaporator? Ive never seen one go bad.
Old May 20, 2006 | 02:52 PM
shadeda4's Avatar
man it is a pain i tried to inspect my ac drain line cause my car was leaking water on the floorboard and i though i fixed it but now hot as water is comming from under neath the dash it use to be cold water leaking in now its hot i dunno if i have a bigger problem the dash is all in the way such a pain
Old May 20, 2006 | 03:03 PM
CRAZYHAWK's Avatar
If there is a small leak in the evaporator, you might try adding a can of R143a with lubricant and stop leak.
