Caliper Paint / Before & After
Old Aug 28, 2006 | 06:00 AM
evoic's Avatar
Default RE: Caliper Paint / Before & After
Thanks for the kind words folks.
I was torn between doing the top carrier and leaving the grey bar and undersides, or doing the entire thing in red and only leaving the bar unpainted.
I still may go back and check for touch-ups and decide to paint the rest of the assembly red.
ORIGINAL: Sleeper
Where did you buy your kit and do they have it in black?
Kragen.....$16
It's a DupliColor kit. They have them in Black, Red, and Blue.
ORIGINAL: zat0rsk1
what paint did you use? and did you use any clear coats or primers or anything? i want to do that. Red looks good on any car. nice work
I used the brush-on kit. No clear coats, no primer.
I washed the calipers, sanded them down in case I missed the tough stuff, washed them again, sprayed on the caliper cleaner and started laying coats.
The stuff dries fairly fast. I'd say about 85% dry in 5 minutes. Once I got to the back, the bottom, and then the nooks and crevices - the top would be dry and I would start with the next coat.
Since I'm self-admittedly OCD, I probably laid about 5-6 coats to make sure I got everything (still missed a few tiny little spots) and had it shiny the way I wanted it.
ORIGINAL: Sleeper
[:-] so how does it work? Just paint it? I think it'll looks sick if my calipers were black too
See above.
ORIGINAL: PandaXpress
cant wait to see em in person jeff
u gonna go eat some lobster wit us rite
I'm 99% sure I'll be joining the gang for lobster.
Looking forward to the next GTG.
Old Aug 28, 2006 | 06:20 AM
evoic's Avatar
1. My Obsessive Compulsive nature almost guarantees that I will have to take the wheel off and do a tiny touch-up to the spots in the black boxes.
2. The rust looking stuff on the rotor wipes right off. That's over-spray from the caliper cleaner.
3. Should I paint the sections where the arrows are pointing in the pic or leave them like they are?
Old Aug 28, 2006 | 11:40 AM
blkapra4's Avatar
1: definitly touch up the boxes
2: dont paint the arroe sections it looks fine as is
Old Aug 28, 2006 | 12:43 PM
ADubyaD's Avatar
SoCal Crew Member
i did paint that area on mine, mine are a bit different tho, i think yours look good as is tho, caliper paint does wonders... ill show you mine if your at the next gtg
Old Aug 28, 2006 | 03:41 PM
evoic's Avatar
Sounds good. You'll be there for the Lobster GTG or the next one?
Old Aug 29, 2006 | 04:07 AM
evoic's Avatar
It sucks.
I'm kinda' not feeling my own mod......lol.
I did a perfect job, the paint is as good as it's going to be done by anyone using a brush-on kit, but something about isn't working for me.
I think I expected to be a little more wowed by the result, but I'm kind of indifferent towards it.
It doesn't look AMAZING.....it doesn't look DREADFUL......it's just kind of.....there.
Any ideas on removal in case I decide to get crazy?
Old Aug 29, 2006 | 04:13 AM
SlowWagon08's Avatar
hahaha you're nuts!! it looks great! makes it look bigger!! if you take it off you'll miss it!
Old Aug 29, 2006 | 06:05 AM
  #18
sandman's Avatar
heres mine, i did them about a year ago.
Old Aug 29, 2006 | 06:24 AM
  #19
that looks so clean...that was just the spray wasn't it?
Old Aug 29, 2006 | 07:11 AM
  #20
PKSJeter's Avatar
looks real clean man. i painted the lower bar on mine black instead of red(my car is red with black). i had 10 years worth of brake dust on mine so i used a pneumatic drill and a wire brush to clean them, you might take the paint off the same way if you decide to. i think it looks great tho. and those nicks in the paint are gonna happen unless you go with the powder coat. good job.
