Cam chain
Old Nov 27, 2007 | 02:57 PM
khj677turbo's Avatar
Default Cam chain
Searched it up a little bit, still kind of confusing. At idle(when my car worked) it seemed to be a bit noisy, when it was taken in i was told it was a result of wear on the cam chain area. As im taking out the head, would it be a good idea to replace the chain, chain tensioner or both??
Any insight would be delicious.
Old Nov 27, 2007 | 03:00 PM
auditurbo381's Avatar
Default RE: Cam chain
check oil pressure. if up to par replace tensioner. chain should be fine. if oil pressure is low first try your oil pick up tube.
Old Nov 27, 2007 | 03:01 PM
hiwords's Avatar
people usually replace the tensioner itself. how does ur head look? sludgy? might wanna do a little bit of cleaning while ur in there
Old Nov 27, 2007 | 03:03 PM
aRIf's Avatar
mine is noisy too but not much. It's atime comsuming job so I passed.
agreed. seafoam would be good. i saw no sludge residue in my head or in my pan. but the thing still went bad. sorry, seafoam might help. but sounds like you need a new tensioner. check oil pressure first!
Mlaubach
Aug 20, 2008 01:38 PM
Cruz734
May 1, 2007 09:19 PM
keko2004
Oct 12, 2006 11:21 PM
Imejia
Sep 16, 2006 04:24 PM
