cam seals diy?
Old Jun 6, 2007 | 09:35 PM
wemmington's Avatar
Default cam seals diy?
Im putting in a new engine in my 98 A4 1.8t fwd and will be replacing the timing belt,water pump and a bunch of other things. Is there a diy anywhere for the cam seals? The seals came with my timing belt kit but I cant seem to find any info on how to replace. Any special tools? I've done a timing belt on a a4 2.8 before but i'm not sure how tough of a job it will be to do the seals.
Thanks
Old Jun 7, 2007 | 11:09 AM
wemmington's Avatar
Default RE: cam seals diy?
Someone must have done their seals? Anyone?
Old Jun 8, 2007 | 09:23 AM
akielb's Avatar
Bump - I think this is a very eazy thing to do once you are in there doing the TB, I don't think there are any special tools that are needed for this job. Can someone else verify
Old Jun 8, 2007 | 09:27 AM
techbod's Avatar
seals are easily fitted if you use a socket the same size as the seal and lightly tap it in "square" and a screw driver to hack the old one out
Pitao
Sep 18, 2013 09:59 PM
gwos25
Nov 10, 2009 01:08 PM
jason955
May 28, 2008 12:59 AM
JcoyA6
Mar 10, 2008 12:26 PM
mrdb85
Oct 31, 2006 08:56 AM
