Cams
Old Jan 11, 2008 | 06:40 PM
tooxtreme8813's Avatar
Default Cams
Is there any mild cams out there that I can use with a GT2871r elim? I'm looking for some mild cams to maybe put it. I have my whole engine apart for all kinds of gaskets and maintenance and it would be a nice time to throw in some cams
Old Jan 11, 2008 | 07:03 PM
Default RE: Cams
im looking at either cat cams or revolver
Old Jan 11, 2008 | 09:50 PM
khj677turbo's Avatar
Default RE: Cams
https://www.audiforums.com/m_756683/tm.htm
Have you read that thread? Seems like cams are pointless to me... but i dunno.
Also, unless you have the head off, im pretty sure it would be a huge pain in the *** to switchthe camsout, right?
Old Jan 11, 2008 | 09:55 PM
sean1.8t's Avatar
Default RE: Cams
ORIGINAL: khj677turbo
with the right steps taken, you can switch the cams in only acouple hours with the head on.
Old Jan 11, 2008 | 09:59 PM
sean1.8t's Avatar
Default RE: Cams
ORIGINAL: tooxtreme8813
not really going to see any gains from cams on a 28 series turbo.. a gt3071 or bigger and you'll be able to utilize them..
might want to look into some N/A 1.8t cams. the way audi engineer's work, there might be something there, but i've never seen anything.
try vortex
Old Jan 12, 2008 | 12:58 PM
cincyTT's Avatar
I'm make believe
Default RE: Cams
cams are going to help keep the tq from falling off. With a gt28 turbin wheel, the rpms arent really long enough for full benifit. Sure you will see some increase, but not as much as with a larger gt30 series turbo. Guessing some mild cat cams (qedpower.com) would only net about 10-20whp.
Old Jan 13, 2008 | 11:10 PM
sean1.8t's Avatar
Default RE: Cams
right. it's really just going to shift the powerband up the rev range a bit.. and with the constricting flow of the elim exhaust housing, i wouldn't see it gaining more than 10whp peak.. if it was a full t25 gt2871r, then i'd suspect maybe 20 or more whp, and would think it would be worth it. but i just don't think it would be worth it for this turbo
Old Jan 14, 2008 | 05:07 AM
Default RE: Cams
ORIGINAL: sean1.8t
ill probably end up going bigger and since i have easy access and one of the cams is already out i though i would just throw in a new set
Old Jan 14, 2008 | 12:34 PM
cincyTT's Avatar
I'm make believe
Default RE: Cams
w/o tuning, your not going to see anything. Plus there will be other cost incurred when install them. Unless you plan on a gt30XX turbo, dont waste your time or money
Old Jan 14, 2008 | 01:14 PM
Default RE: Cams
ORIGINAL: cincyTT
what other costs are incurred when you put in cams?
