can clogged fuel filter cause a car to run rich?
Old Jun 28, 2006 | 03:16 PM
rnbguy's Avatar
Default can clogged fuel filter cause a car to run rich?
hmmm?
Old Jun 28, 2006 | 03:18 PM
onepoint8tee's Avatar
Default RE: can clogged fuel filter cause a car to run rich?
Maybe lean but not rich.
Old Jun 28, 2006 | 04:33 PM
StepUpProductions's Avatar
^^^ precisely
Old Jun 28, 2006 | 06:19 PM
wood_e's Avatar
If its clogged your car may not be getting good fuel pressure, this will cause the car to run lean. If you are indeed running rich your fuel pressure may be higher than normal. I suggest that you check the pressure.
Old Jun 28, 2006 | 06:24 PM
blackvision999's Avatar
a bad maf would make you run rich also a bad o2 sensor or bad timing
Old Jun 29, 2006 | 12:49 AM
LarryInPA's Avatar
Check your air filter, too. The computer will prevent a clogged air filter from creating a rich fuel condition, but performance will be restricted.
Old Jun 29, 2006 | 10:00 AM
david9999's Avatar
Run a vagcom and pull the codes.
Could be anything from bad oxygen sensor, leaky fuel injectors, MAF, fouled plugs, very dirty air filter, etc.
How do you know you are running rich?
Old Jun 29, 2006 | 04:14 PM
acetrebo's Avatar
bump,
rich condition should generate codes. Why do you think its running rich? What codes are you getting?
Old Jun 29, 2006 | 04:24 PM
techbod's Avatar
im for that, wow no avevor makes me wonder if I already answered this get your fingers out otherwise ill put my own back on
[IMG]local://upfiles/12092/CD6D86C2383A4E8B85DB1EBFEB06D035.jpg[/IMG]
Old Jun 29, 2006 | 04:28 PM
techbod's Avatar
its back till you get a better one
