Can i change my idle speed?
Old May 6, 2007 | 02:44 PM
brent07's Avatar
Default Can i change my idle speed?
Wow it's been a while since i've been on here
98.5' A4 2.8l 30v. Just wondering if i can raise my idle to around 1k. does it require any special tools or how hard is it ?
Thanks guys,
Old May 6, 2007 | 03:18 PM
x1rider's Avatar
Default RE: Can i change my idle speed?
I'm not sure if it would work with your car and I haven't had a chance to try it myself but the program that you can download using the link allows you to make some modifications using a Ross-Tech Vag-Com cable. !!!try at your own risks!!!
http://www.unitronic.ca/uni/index.ph...&Itemid=58
Old May 6, 2007 | 05:06 PM
sean1.8t's Avatar
ORIGINAL: x1rider
no, that wont work for him. he is dbc where as this unitronic software and the revo software like this only works for dbw cars; I.E. 2000 model years and up
Old May 6, 2007 | 05:43 PM
x1rider's Avatar
good to know, thanks for the info!
Old May 6, 2007 | 07:34 PM
brent07's Avatar
so i have to have go somewhere with a computer ?
Old May 6, 2007 | 08:37 PM
Pablo_Ottawa's Avatar
Why would you want to do that anyways? If your car is not idling properly there's something wrong and masking it by upping the idle speed doesn't make the problem go away.
Old May 6, 2007 | 09:08 PM
Bondga's Avatar
if your dbc you should just have to adjust the cable so that the valve stays open a little more. If your car uses an IAC(Idle air control valve) you'ss need to adjust it through the computer
Old May 6, 2007 | 10:45 PM
Jeff's Avatar
Zombie Defense Force
whats the point? you will just use more gas
reverend
Apr 30, 2009 12:06 PM
wmdunk
Jan 27, 2008 06:54 PM
afek
Oct 18, 2006 05:43 PM
captcaos2002
Aug 8, 2006 06:04 AM
brogenville
Jan 3, 2005 10:33 PM
