can my sucking in hot air make car run richer?
Old Jul 3, 2006 | 10:38 AM
dafrazi's Avatar
Default RE: can my sucking in hot air make car run richer?
Have you checked the FPR?
Old Jul 3, 2006 | 11:01 AM
techbod's Avatar
00561 = mixture control possible causes are trouble codes 00525/00533 stored, low fuel level, fuel pressure/pump, intake/exhaust leak, misfire, MAP sensor, o2 sensor, EVAP canister purge valve, injectors leaking, excessive fuel in the engine oil this would have been caused by over fueling
Old Jul 3, 2006 | 11:19 AM
rnbguy's Avatar
ok we'll start top of that list, thats one thing i learnt from this forum and its start simple then work ur way up...
how do i check the fpr?
by the way im sure intake is fine the g/s peaks at 166
Old Jul 3, 2006 | 11:31 AM
techbod's Avatar
FPR = fuel pressure regulator so you need a fuel system vacuum tester for that
some tips here on how
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
vacuum testers
http://images.google.co.uk/images?q=...m+tester&hl=en
Old Jul 3, 2006 | 12:01 PM
dafrazi's Avatar
Easiest way to check, is to try swapping it with another FPR from another Audi. Or, you can buy one fairly cheap $40-$50.
Check the vacuum hose going to the FPR too.
Old Jul 3, 2006 | 03:44 PM
rnbguy's Avatar
its weird bcuz i just changed vacum hose bcuz i noticed the old hose was getting old.... could the new vacum hose be a dud??? its one of them stratch material ones that are tight and stretch around the output of the fpr (like the tip of a baloon)
Old Jul 3, 2006 | 04:59 PM
wood_e's Avatar
Like I said in another thread of yours... check your fuel pressure...
Old Jul 3, 2006 | 05:01 PM
  #18
rnbguy's Avatar
by getting a guage???ne other way threw vag?
Old Jul 3, 2006 | 06:10 PM
  #19
dafrazi's Avatar
Did you use vacuum hose when you replaced the hose to the FPR? It's not wise to use just any old hose. You need to use vacuum hose becuse it's designed not to collapse under vacuum.
Old Jul 3, 2006 | 07:17 PM
  #20
wood_e's Avatar
Yes, by getting a gauge. That way you know what it is FOR SURE. I got mine at harbor freight for $10.
