Cannot put my key in the ignition?!
Old Aug 17, 2007 | 04:50 PM
jdes's Avatar
Default RE: Cannot put my key in the ignition?!
ORIGINAL: david9999
Assuming you aren't in the wrong car, it may be that the ignition lock is worn out and needs to be replaced.
Yeah I'm thinking probably that. My father first had the problem and I thought that he was just being ignorant. He eventually got it to go in after my jiggling, shaking and crossing fingers. Now it won't work period. It's like there's something physically preventing it from going in.
Old Aug 17, 2007 | 04:52 PM
jdes's Avatar
ORIGINAL: 96audia4
Is it possible that someone (like a small child) shoved something in there? Can you see if something is in there blocking the key? What year is your car?
It's a 96. It has that metal trap door-like thing preventing me from looking into the ignition. It only opens when you push the key through it.
Old Aug 17, 2007 | 04:55 PM
jdes's Avatar
How easy is it to replace the ignition?
Oh and as far as the "is he serious?" "it soundsshady to me" comments. Just try to be helpfull that's what forums are for.
Old Aug 17, 2007 | 06:35 PM
Darknight101's Avatar
Get a can of WD40 and something to clean up the key with. First off you want to make sure its the right car jk... Take the red tip of the can and shove it in I'm guessing the trap door on it is bent or a spring came off in that case have fun getting it out or just replace it. Next Spray like mad and let sit for 1 min inset key if you can if not you'll have to force something to brake that door open when doing that your SOL if it jams in and dosent pop loss and move like it should. When key is in move it around in and out in and out.... Wipe key and repeat about 5 times to clear the junk from inside the lock. Low and behold this will also work if the lock just dosent wont to turn with the right key.
If your in a heavy dust or humid area its a good idea to do this about every 6 months just for fun it makes a huge differnace and its simple.
Old Aug 17, 2007 | 07:06 PM
sdsteez's Avatar
never had the chance to say this so......[sm=ttiwwp.gif]not exactly worthless, but hard to help if we dont know what youre talking about
Old Aug 17, 2007 | 09:49 PM
96audia4's Avatar
96 A4's have a recall for the ignition switch. You can call the dealer and get them to do it, or just do it yourself. Personally, I would DIY b/c its pretty easy and cheap.
DraxeofDclan
Feb 28, 2009 09:24 PM
techguru
Jun 18, 2007 10:17 AM
raffysaudi
Oct 10, 2006 01:37 PM
sid0013
Jan 23, 2005 07:25 PM
