CAN'T FIND REALLY BAD COOLANT LEAK!!!!
Ok,
So i have a really bad coolant leak right now and I can't find it! On Sunday when I was at the SoCal G2G I topped off my coolant because it was low. I filled it all the way to the max line. Then just today (Tuesday so 2 days later) my coolant low light came on. I checked it and it was ALMOST COMPLETELY EMPTY!!!! Thats an entire tank of coolant in 2 days! I have looked around for the pink crusty stuff but can't find any. Any ideas on where it could be coming from? It could be the water pump but I can't tell... Any help would be great. $23 a bottle for coolant is going to kill me at this rate!
Josh
Josh
There is a TSB for an o-ring leaking out of a coolant plug right next to the thermostat housing. It only leaks when the engine is cold.
Check under the intake manifold with a flash light next to the thermostat housing and check to see if its wet or if you can see the red crap.
Onepoint. Yes I did. It was a bad o-ring on the old sensor. When I replaced the sensor it fixed that leak. It was fine for about 1 1/2 months or so. Now it's acting up again and it's really bad. i have not had a chance to get completely under the car yet. Now that I am back in school I don't have as much time and I don't have any of my tools with me [:@] I didn't have room to bring them down with me.
AudiTech. I will check that out tomorrow. Thanks.
Josh
Josh
Yeah, you might as well kiss your *** good bye without tools. If thats not it, check the coolant flange again where it connects to the block, that is a real *** kicker.
ORIGINAL: auditech79
ORIGINAL: ThePaintballGuy
Where is that post at???
Search is GOOOOOOOOOOOOOD [8D]
ORIGINAL: onepoint8tee
I remember you explaining that a while back. I took a close look at it the other day and to say its "a real *** kicker" seems to be an under statement [:@].
