Can't get out of Park!!!
Old Oct 21, 2007 | 04:39 PM
liv2wrshp's Avatar
Member
Default Can't get out of Park!!!
Please help!!!
I have a B5 A4. I replaced the brake light switch several months back.
Yesterday, it took me a couple times hitting the brake to get the car to recognize it and let me shift out of park. On the way home, I recognized that when I hit the brake the lights weren't coming on. Well, I thought it was the sensor again. When I looked under there, I noticed there are two very similar looking sensors connecting to my brake pedal. I can't remember which one is the brake light sensor. Also, what is the other one?
Thanks ahead of time!!
I need to get this figured out so I can go to work tomorrow!!!!
Old Oct 21, 2007 | 04:49 PM
hiwords's Avatar
Default RE: Can't get out of Park!!!
it's either a bad brake switch or there's sumthing wrong with ur shifter. ewll there's a little sqaure by ur shifter with a slit on one side of it. if u open that and stick ur key in, it'll do that same thing as applying the brakes to shift. that's a temporary solution so u don't get stranded though. get the problem fix, don't delay it lol
Old Oct 21, 2007 | 04:56 PM
liv2wrshp's Avatar
Member
I can't find that square you're talking about. I was hoping that there was one, but no dice. As far as the switch, do you know which one? There are two one above another.
Old Oct 21, 2007 | 05:04 PM
hiwords's Avatar
i have no idea wut switch sry. and ur right, doesn't seem like there's a little square thing on the audi. pm auditech79. he for sure will be able to tell u
Old Oct 21, 2007 | 09:44 PM
david9999's Avatar
Most likely it is the brake interlock switch. It is what prevents you from taking the car out of park unless the brake pedal is pressed. Unfortunately, I don't have my Bentley with me, so I can't give any more details.
Old Oct 21, 2007 | 11:37 PM
mark_2328's Avatar
I think you need a third pedal.. That would solve your problems.
Old Oct 22, 2007 | 10:40 PM
liv2wrshp's Avatar
Member
K, found out the the second switch is for the cruise control and has a vacuum line attached to it. I'm going to change out the brake light switch one more time and see what happens!
Old Oct 22, 2007 | 10:43 PM
auditech79's Avatar
ORIGINAL: liv2wrshp
Don't break it.
bmcmanus
Nov 15, 2010 01:04 PM
mnets
Feb 9, 2007 04:19 PM
AWDaholic
Jan 30, 2007 04:12 PM
