carbon fiber main intake A4 1.8t
Old Dec 14, 2004 | 01:07 AM
alejandrorodrigu's Avatar
Default RE: carbon fiber main intake A4 1.8t
ohh thanks, you save me
Old Dec 14, 2004 | 01:47 AM
trailboss's Avatar
ORIGINAL: 04a4
I have talked to a bunch of performance shops about this intake and it Looks cool, but acutall hurts your performance b/c it pulls hot air from the engine compartment rather than the stock intake that pulls from the front grille. In my opinion it is not worth it.
Yep, not only this intake but all intakes for the A4, but if you duct air to it then you can see increases. Or Make a custom intake like i am. I have the EVO MS intake and im going to make piping to go down to the front lower grill and have it there, but i gotta reasearch a way to make it so water doesn't get in there. Or fabricate a way to use one of the AEM things they make for there intake so water doesn't make it all the way through the intake.
Old Dec 14, 2004 | 01:51 AM
i was reading that i can put something like a supercharged (electronic powered) on the intake, and it works better, waht do you think about it ?
David_K's Avatar
ORIGINAL: trailboss
ORIGINAL: 04a4
wrong dude hot air before a turbo has no effect because you have an intercooler. you can pull as much hot air as you want. it doesnt matter if the air going into the turbo is -30 or 1500 because it goes through the turbo and the turbo heats the air to 1600. so yes you will see power gains from open air filters. but that big bulky carbojn fiber thing is just to bulky to work
you dont have to fabricate anything for the AEM bypass. all you need to do is cut the pipe and peice it together. and putting a filter in the bumper will hurt your performance because of all the twists and turns you have to take. If you had a V6 you would see gains.
Old Dec 14, 2004 | 01:52 AM
David_K's Avatar
ORIGINAL: alejandrorodrigu
i was reading that i can put something like a supercharged on the intake, and it works better, waht do you think about it ?
doesnt work. at the velocity your turbo pulls air in the fan blades will create a blockage of airflow the same way the exhaust turbine makes backpressure at full boost.
Old Dec 14, 2004 | 01:54 AM
in mexico the new a4 b6 (2005 not b7 in mexico) has 190 hp, and i saw that the only difference for the 20 hp (170 to 190) is the second intercooler, is that true ?
Old Dec 14, 2004 | 01:56 AM
zachd's Avatar
ORIGINAL: David_K
ORIGINAL: trailboss
ORIGINAL: 04a4
AMEN
Old Dec 14, 2004 | 01:58 AM
  #18
David_K's Avatar
yes
ECS Tuning
Jan 22, 2015 01:53 PM
Prizmatik
Nov 28, 2012 12:44 AM
cummins990
12
May 13, 2011 02:19 AM
zectasy
Jul 8, 2007 03:02 AM
DaGimp
Dec 30, 2004 02:37 AM
