ECS RACE N75s
Old Dec 14, 2004 | 12:56 AM
alejandrorodrigu's Avatar
Default ECS RACE N75s
are the same 710N Diverter valve and ECS RACE N75S
[IMG]local://upfiles/3506/670EB594318049289E38925B4604C713.jpg[/IMG]
Old Dec 14, 2004 | 01:15 AM
trailboss's Avatar
Default RE: ECS RACE N75s
No completely different. The n75 valve is a wastegate bypass valve. It pretty much is a valve that controls movement of the wastegate actuator. The 710N is a diverter valve which reroutes air back through the intake system. I have the race N75 valve and it added 2 psi of boost and made it so it doesn't spike so much. It made the boost hold stronger and a little longer. Don't think you get 10hp out of it like ECS says, id say 2hp if you have any gains in boost. Make sure it is compatable with your year A4 if you get it
Old Dec 14, 2004 | 01:29 AM
ok, do you think that i have to put in my car the n75s ?
Old Dec 14, 2004 | 01:38 AM
trailboss's Avatar
No you don't have to, its not somethin most people do. I did it b/c i was only seeing 15lbs of boost and it has been said i should spike at 18-19 so i put the ecs n75 race valve in and i know spike 18 and hold 16. The 710N DV is something most people do when they chip but i think your car already has one. Id upgrade the DV before i got the N75 race valve, i really don even think anyone else has one on this site, maybe a few others.
Old Dec 14, 2004 | 01:41 AM
what do you think about changing the stock fuel injectors for the 225 tt or the 225 s3 ?
Old Dec 14, 2004 | 01:52 AM
trailboss's Avatar
You have APR, they make a program to run with bigger injectors, 91 oct = 229hp/271lb-ft. Or 93 oct = 235hp/275lb. Don't run different injectors without having the right software for it, you could kiss your engine goodbye if you do.
Old Dec 14, 2004 | 01:59 AM
did you know how much does the injectors costs (price) in the us?
Old Dec 14, 2004 | 02:01 AM
sfordeso's Avatar
I liked your other sig better...
Old Dec 14, 2004 | 02:03 AM
trailboss's Avatar
the apr site doesn't even say what size injectors they use so i don really know.
Audi Forums Editor
Jun 22, 2013 08:28 PM
Audi Forums Editor
Feb 12, 2013 04:38 PM
Jchockey100
Feb 6, 2012 08:44 PM
Stevenw83
Oct 26, 2009 02:12 AM
SuprA4
Mar 27, 2008 12:23 AM
