Cat converter questions...
Old Nov 12, 2006 | 04:06 PM
wood_e's Avatar
Default Cat converter questions...
So my cat converters have been rattling like a BITCH the past few days. Since I'm trying to narrow down a knock as well I'd like to fix this. It's probably the heat shield but I've got a few questions...
1) I assume if it is the heat shield I can just remove it and not have any harmful effects, right?
2) Do the post cat O2 sensors let you know when you need new cats? Are there other ways to tell? (I know tapping them can reveal a bad cat)
3) Does it matter what kind of converter to get so long as it's OBD2 compliant?
TIA!
Old Nov 12, 2006 | 07:57 PM
wood_e's Avatar
Default RE: Cat converter questions...
no one?
Old Nov 13, 2006 | 12:55 AM
wood_e's Avatar
bump
Old Nov 13, 2006 | 01:59 AM
acetrebo's Avatar
Well, removing the heat sheild wont cause any problems, other than the risk of fire depending on what the car is over top of. I.e dont park under a tree in the fall where there are dry leaves on the ground.
2. IDK this one
3. I would think that a certain size is needed to fit in the area where it goes. I dont think all cats are a standard size, but not sure.
I think you found one, didn't you? Saw it in another post I thought. If not, check ecstuning.com, or atp website, or others that sell exhaust systems for our cars.
Old Nov 13, 2006 | 02:16 AM
wood_e's Avatar
Yeah I found a magnaflow 2.25 inch one for $54 or so that should fit.
b5_4ever
Oct 8, 2011 06:23 AM
host23age
Mar 26, 2011 11:32 PM
btmlinedan
Jan 3, 2011 01:45 PM
walters41907
Jan 31, 2010 05:00 PM
socaljoe
Dec 5, 2007 05:09 AM
