CEL
Old May 5, 2006 | 01:18 PM
kaklexicon's Avatar
Default CEL
Lately I've been having issues with my speedo not working sometimes.. but the CEL never came on before. It finally came on yesterday when the speedo wasn't working. So I disconnected the battery, took out the instrument panel, checked the wires and everything in the back. everything looked ok. put it all back together, turned it on, and the CEL was gone. Even though the CEL went away is the code still stored in there?
Old May 5, 2006 | 01:41 PM
BFlan2001's Avatar
Default RE: CEL
yes, the code will still be stored in the ecu until you clear it out...sounds like you might have a failing engine speed sensor...~100 bucks and a pretty simple installation
Old May 5, 2006 | 02:48 PM
kaklexicon's Avatar
Default RE: CEL
hmm.. where is the engine speed sensor?
Old May 5, 2006 | 03:59 PM
onepoint8tee's Avatar
Default RE: CEL
I dont have my bentley here.. But on my maxima it was right on top of the tranny and accesible from the engine bay.. That may not be the case for an audi, but it makes sense it would be on the tranny somewhere.
Old May 5, 2006 | 04:06 PM
techbod's Avatar
Default RE: CEL
its on the transmission but to test it you have to go to the ECU pins, put an LED between pins 3 and 20 now switch ignition on and spin left front wheel the led will flash to confirm its ok
Old May 5, 2006 | 05:06 PM
kaklexicon's Avatar
Default RE: CEL
hmm.. so it's on the tranny. That's underneath the car towards the back. Is it a bitch to get to?
Old May 5, 2006 | 05:09 PM
kaklexicon's Avatar
Default RE: CEL
Wait, it's not this thing is it?
Old May 5, 2006 | 05:10 PM
techbod's Avatar
Default RE: CEL
thats the o2 sensor
Old May 5, 2006 | 05:11 PM
techbod's Avatar
Default RE: CEL
first class picture though
Old May 5, 2006 | 05:12 PM
Jestnomen's Avatar
6th Gear
Default RE: CEL
ORIGINAL: bentframe
If he disconnected the battery the code was dumped.
kaklexicon, if you are serious about working on your car go buy a Vag-Com from Ross-tech.
