CEl and AIR BAG light
Old May 20, 2007 | 10:44 AM
pilot5.0's Avatar
Default CEl and AIR BAG light
OK gurus you've helped me before. Did multiple searches and was able to fix AIR BAG light. VAG had drive and passenger resistence too high. Unplugged both connections under seats and put on small amount of dielectic grease and reset(light out).
Problem 2 CEL- VAG has Throttle body malfuntion part, and throttle body unable to reach lower limit. If Idisconnect the battery and re-connect, the CEL goes out(with VAG reset of engine codes). Then I complete a manual throttle body adaptation and the car runs fine in the drive way, but dies 50% of the time at a stop light. So I complete VAG throttle body adaptation(engine block 098), VAG reports unable/error, but then car runs perfect but the CEL is on steady and codes are present.
Old May 20, 2007 | 05:00 PM
david9999's Avatar
Default RE: CEl and AIR BAG light
1. Cool.
2. What is the code and I'll check my Bentley for troubleshooting.
Old May 25, 2007 | 12:56 PM
pilot5.0's Avatar
I'll get the codes. What cleaning can be done. Can any voltages be read out with a voltage meter?
Old May 25, 2007 | 01:09 PM
techbod's Avatar
# more to follow
[IMG]local://upfiles/12092/B3C15A1E6FD6427880CA5CC929706ECD.jpg[/IMG]
[IMG]local://upfiles/12092/7FE86D6D7EE24F38B0652C76423A513D.jpg[/IMG]
Old May 25, 2007 | 01:11 PM
techbod's Avatar
[IMG]local://upfiles/12092/46836124A4BB4C10A35C0A1A971934EE.jpg[/IMG]
[IMG]local://upfiles/12092/CC73A9AC443E432CBFA9C4893F9903DD.jpg[/IMG]
Old May 25, 2007 | 01:12 PM
techbod's Avatar
last one
[IMG]local://upfiles/12092/9DA915B711574DE9888D1DBB2A9BBDB2.jpg[/IMG]
Old Jun 17, 2007 | 07:52 PM
pilot5.0's Avatar
avant80. Sorry out of country for a while.17973throttle control(j338) Fault in basic setting p1559-35-00, 17973 throttle actuator(j388) Lower stop not reached p1565-35-00, 18147 tiptronic up switch(f189) short to ground 18141 tiptronic down switch short to ground.
Anyone thanks in advance for answers. Is it more likely to be steering wheel switch of shifter switch?
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
