CEL cherry poped w/codes....
Old Jul 25, 2006 | 09:00 PM
onepoint8tee's Avatar
Default CEL cherry poped w/codes....
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Any ideas? Im about to consult the bentley.. But this is the first place i ran to get some oppinions.. I have gotten the 17964 code several times after getting chipped. I guess its from overboosting, and had this code before putting in the n75 race valve in. It goes into limp mode and i get this code.. all ive ever had to do was restart and limp mode went away even if i didnt clear the code. NOW... i cleared the same 17964 code last night and its back, and i have these 2 other codes along with a cel and stuck in limp mode-max 10 psi. If the engine coolant temp sensor is bad, wouldnt that cause me to run rich rather than lean? and i posted yesterday about the "cracking noise" i heard like endle had about a week ago too.. Im thinking it was in fact detonation due to running lean. I've dreaded this day for almost a year now. i feel so violated.. please help me out with some ideas if you got em! Thanks.
Old Jul 25, 2006 | 09:12 PM
CRAZYHAWK's Avatar
Default RE: CEL cherry poped w/codes....
Consider changing the temperature sensor as they often go bad.
Old Jul 25, 2006 | 09:26 PM
ya im deffinately considering that as its probably the cheapest way to start troubleshooting. Thanks.. but i figured a bad etcs would give a low signal as opposed to a high one if it were bad and id run rich instead of lean.. i didnt think a high signal and lean condition was a sign of a bad etcs...
Old Jul 26, 2006 | 01:08 AM
Any other ideas anyone? I have also been reading that the 17536 code could mean a bad maf. I'll be doing some logs with vag tomorrow and replace the ects because i dont have the revised green one, and ive been reading about how the stock black one is very troublesome.
Old Jul 26, 2006 | 02:13 AM
Beer Mod's Avatar
ORIGINAL: onepoint8tee
17964 - Charge Pressure Control: Negative Deviation over boost (chip + n75)
16502 - Engine Coolant Temp. Sensor (G62): Signal too High You know it needs replaced
17536 - Fuel Trim: Bank 1 (Mult): System too Lean Again the chip + n75, MAF, FPR, and the list could go on P1128 - 35-00 - -
That's all I have for now good luck
Old Jul 26, 2006 | 01:52 PM
Thanks.. Im getting the ects today at the dealer for an amazing $6. Thats probably the cheapest part they keep in stock other than hose clamps. I hate being stuck in limp mode. Ill put it in and clear the codes and see what happens. I think the ects signal too high code is causing a lean condition/code because i know a ects with a signal too low will cause a rich condition. we'll see.
Old Jul 26, 2006 | 02:35 PM
techbod's Avatar
Default RE: CEL cherry popped w/codes....
16502 could be the cause of all the other codes, coolant thermostat, wiring open circuit/short to positive, ground wire defective or the ECT sensor is shot
Old Jul 26, 2006 | 02:56 PM
ORIGINAL: avant80@2.6
Thats what im thinking/hoping.
Old Jul 26, 2006 | 03:03 PM
techbod's Avatar
yep I checked the other codes and came to that conclusion, 17964 is the waste gate stumbling but only once so all other codes are intermittent
Old Jul 26, 2006 | 11:43 PM
Put in the ects a couple hours ago.... Cleared the codes... Drove around for about a half hour and all is good so far. No more limp mode/CEL and no codes returned. I guess the true test is to give it some more time. I have noticed a couple positive things though, the engine seems to idle a lot smoother and the lag between shifts is pretty much gone under wot (tiptronic)-before it used to buck a little between shifts and it seems to have smoothed out now which is something i read about as a bad ects symptom on audiworld- i guess with tip/auto, cars the throtle isnt closed while shifting and if the ects is bad it causes you to either run way rich or lean during the shifts. So now i can actually chirp the tires while going into 2nd gear again-something i forgot about after getting chipped.. (im fwd by the way.) I guess the ects has been on its way out and been affecting my performance for about 8 months now. Seems like this $6 part has rejuvinated some lost power for sure. Anyone with the black top ects replace it with the revised green one even if you dont have a cel or code!!! I really feel that this part has been taking away some performance for quite some time- no placebo affect about it. Took me literaly 2 minutes to install.
