CEL cherry popped
thanks guys. i took my car to autozone and the first and only code i had was P0131=low voltage bank 1 sensor 1.
i then messed around with all the o2 connectors to see if there was moisture or a bad connection and they looked good. i disconnected the battery for 30min and the light came right back on no hesitate at all. i then went back to autozone and the scan came up with P0131 and P1128.
2 questions
1. where is bank one sensor one. i know its a pre cat but is that on the driver or passenger side?
2. Low voltage? is that a sign of a bad sensor or just one that isnt connected right?
2 questions
Bank one is passanger side. A bad 02 sensor will cause a low voltage signal. If you have anywhere near 100k miles it would be wise to change both pre cat 02 sensors. As they get lazy so does your car.
soul strong
Feb 28, 2009 09:10 PM
