CEL Codes P0137 and P0455
Old Dec 17, 2010 | 09:47 PM
dyazdani's Avatar
Default CEL Codes P0137 and P0455
I have a '99 A4 Quattro 2.8 and pulled the P0137 O2 sensor low voltage code along with a P0455 gross evap leak code. These were reset a couple of times already, the P0455 wasn't there before, but the small leak (P0442) was...
Is the P0137 usually the O2 sensor itself, or are there other things to check along the way?
P0455 is often the gas cap, it was tested at inspection and found to be good, but possibly doesn't seal in the car itself. What other likely culprits should be checked?
Thanks in advance.
dbdezyne
B7 Models
Oct 18, 2013 04:09 PM
MissionCtrl
Dec 28, 2007 09:08 PM
madrasautoparts
Nov 21, 2007 02:31 PM
cfBrianEvans
Dec 16, 2006 03:49 PM
smokeU
Jul 12, 2006 05:58 PM
