P0455
Old Jul 11, 2006 | 11:27 AM
smokeU's Avatar
Default P0455
http://www.obd-codes.com/trouble_cod...cted-large.php
CEL and this code comes up. I clear. it comes back. is it as simple as tightening the gas cap?
Old Jul 11, 2006 | 11:47 AM
RLB6's Avatar
Default RE: P0455
should be unless there's a leak in the seal of the gas cap
Old Jul 11, 2006 | 11:51 AM
smokeU's Avatar
Default RE: P0455
thats what i figured. and since in JerZ we dont pump our own gas, who knows how the last person put the cap back on... I also just put in a K&N air filter. Could this code have anything to do with the MAF reading?
Old Jul 11, 2006 | 04:02 PM
techbod's Avatar
Default RE: P0455
P0445 refers to the EVAP canister purge valve (short circuit) check the wires
Old Jul 11, 2006 | 05:04 PM
smokeU's Avatar
Default RE: P0455
where's the purge valve????
Old Jul 12, 2006 | 10:42 AM
smokeU's Avatar
Default RE: P0455
ok so I go to check and retighten the gas cap... and its not there! I went back to the gas station that I filled up at last and the guy had it behind the desk. He's lucky he did because I don't think he wanted to see me SNAP!
is there anything I can do? I know there's probly some dirt/dust/moisture from driving around without it for 2 days.
Old Jul 12, 2006 | 12:58 PM
CRAZYHAWK's Avatar
Default RE: P0455
That's why there is a fuel filter.
Old Jul 12, 2006 | 04:34 PM
techbod's Avatar
Default RE: P0455
ooopppppps p0445[:@] when you said p0455 well its the same area EVAP system and its a large air leak detected check all the hoses for splits or if any have come off
Old Jul 12, 2006 | 05:39 PM
smokeU's Avatar
Default RE: P0455
ok so do you think the fact that my gas cap wasnt there is the problem? or is there really a leak? nothing dripping from bottom? but my cap was off for two or three days while I was getting the CEL and the code. cleared it and it hasn't come back yet.
Old Jul 12, 2006 | 05:43 PM
techbod's Avatar
Default RE: P0455
you found your problem it seems gas cap missing for three day would count as a large air leak to the EVAP system so I don't see you having any more problems with it, fixed I would say
