CEL & Diverter update!
Old Apr 8, 2007 | 05:03 PM
Turbulence's Avatar
Default RE: CEL
ok, slow down a little and explain it better ... because i've had secondary air and MAF problems myself before, but i can't understand a single thing your trying to say so i can't help much
Old Apr 8, 2007 | 05:43 PM
akoby9's Avatar
Default RE: CEL
^lol... ok sorry here is what I did.
Took off the air box, disconnected the maf, took off the secondary air tube, took out the inlet for my air box. Took off the top cover to the air box, installed a cone air intake directly onto the inlet that was previously hooked up to my airbox. Took breather filter and put that onto my secondary air tube. The original MAF tube/connection part is still right between my cone air intake and the inlet. Put the covers back on and drove around, then about 30 min later a CEL came on.
I've been trying to search everywhere to see if other pople have had this happen when trying to do what I did... I found something that was talking about having an exposed MAF and that when air gets around it, this could result in imporper readings which could result in my CEL right now. I was thinking about trying to wrap this off, with maybe some type of foil or something. Thoughts?
Old Apr 8, 2007 | 05:54 PM
Bondga's Avatar
Default RE: CEL
did you put the heat sheild back in? and if you have a camera take pics they help. plus i just like to look
Old Apr 8, 2007 | 06:15 PM
akoby9's Avatar
Default RE: CEL
yeah i'll go take a pic...yes i did put the heat shield back... I'm going to try to get one from the az guy though, so its not so ghetto rigged
Old Apr 8, 2007 | 07:08 PM
akoby9's Avatar
Default RE: CEL
Old Apr 8, 2007 | 07:18 PM
Bondga's Avatar
Default RE: CEL
well the good news is it looks liek you did everything right. does your car feel any different when your driving(negatively not positivly) Its possible that the cel might be for something else all together
Old Apr 8, 2007 | 08:12 PM
CRAZYHAWK's Avatar
Default RE: CEL
Have the codes read and post them.
Old Apr 8, 2007 | 09:24 PM
  #18
akoby9's Avatar
Default RE: CEL
ok, i'll try to find someone up here that can read them
also did anyone read my post above talking about trying to wrap my MAF with something to protect it? maybe tin foil? thoughts please
Old Apr 9, 2007 | 09:17 AM
  #19
turbo kraut's Avatar
Tech Guru
Default RE: CEL
i might be off, but by looking at those pics, it looks like your maf might be backwards
what i did to ensure that it was right, is i put it up inside my box and just made sure it was the same when i put it in the new filter
that will cause a cel if it is in backwards
Old Apr 9, 2007 | 12:24 PM
  #20
Bondga's Avatar
Default RE: CEL
i thought that to but when i compared his to mine they look the same. so i assume it's the right way but i'd check neways
