CEL: error codes~
96 A4 2.8 quattro
P0116
P0401
P0304
guy at autozone said something like needing a full tuneup and misfiring... _ _
change those codes into English please? or.. semi-english at least...
Thanks all for the help
P0116
P0401
P0304
DTC: 16500
P-Code: P0116
Description: Engine Coolant Temp.Circ Range/Performance
... possible Coolant Temp Sensor failing
DTC: 16785
P-Code: P0401
Description: Exhaust Gas Recirc.Flow Insufficient Detected
... EGR Check valve failing most likely. Or maybe the EGR passage in the manifold is full of crud and deposits. Could also relate to a Temp Sensor failure.
DTC: 16688
P-Code: P0304
Description: Cyl.4 Misfire Detected
... this could be a lot of things. Ignition control module, plugs, coilpack...
P-Code: P0116
DTC: 16785
P-Code: P0401
DTC: 16688
P-Code: P0304
I posted a reply to you on your thread RAM.
Plugs are simple on 1.8L... i dont know how they are on 2.8L.
Do 2.8L have coils?
Plugs/wires, ICM, ... but I dont think its the ICM, since no blinking cel or multiple misfires.. my best guess is a spark plug....
ECT (Enine coolant temp sensor) is easy on the 1.8L.. not sure on the 2.8L .. i will try to find the diagram...
have fun!
Do 2.8L have coils?
have fun!
