Center Cluster Dash Lights go dim?
Old Aug 24, 2006 | 01:53 PM
snow4fun's Avatar
Default Center Cluster Dash Lights go dim?
My display on my 2000 Audi A4 1.8t is out in the center cluster (Above the steering wheel). It displays Radio Channel, Outside temperature, etc. It actually in colder conditions is readable but as it gets warmer or is on for an extended drives the light gets so dim you can hardly read it. Is there a bulb that you can replace to correct this? Seems weird it works pretty good when you first start the car and then slowly fades to almost unreadable (Usually top starts fading first until it is mostly unreadable). Seems like it is the worst when it is very hot outside. Any ideas what I can do to brighten this back up? - Thanks Scott
Old Aug 24, 2006 | 02:26 PM
Adam@mvp's Avatar
Default RE: Center Cluster Dash Lights go dim?
maybe a bulb maybe like a dimmer switch or something like that.
Old Aug 24, 2006 | 02:32 PM
InsaneHatter's Avatar
these are prone to fail, no bulbs can be replaced, you have to live with it or swap your cluster...
Old Aug 24, 2006 | 02:49 PM
onepoint8tee's Avatar
Ya sounds like you are talking about the "LCD" screen thing. its a terrible design by audi and last i knew there was a class action lawsuit against them about it. Probably wont go anywhere though. My pixels fade in hot weather too. For instance when i had a brake light burn out it read "l ak' Lioht !"
Old Aug 24, 2006 | 09:58 PM
david9999's Avatar
Yep. Only recourse it to change the whole display.
Old Aug 25, 2006 | 01:59 PM
snow4fun's Avatar
Thanks for the info...I'll live with it for now. - L8tr Scott
Old Aug 25, 2006 | 05:07 PM
bluesnapper's Avatar
I have a 99.5 that does exactly the same thing when it is hot the upper display fades, but in the evenings and at night it is crystal clear. Mine seems to be directly related to the temp out side even after the interior cools off from the AC it is still dim.
Old Aug 25, 2006 | 05:13 PM
smokeU's Avatar
ORIGINAL: snow4fun
take a hammer to it! that way when you sell your car you can say it only has 30K miles...
nize
Jun 21, 2013 01:16 PM
dguzzardo22
Sep 25, 2010 12:11 PM
vanbragt
May 3, 2010 10:30 AM
flynnr
Nov 24, 2008 05:13 PM
