Changed my atf fluid/filter today
Old Aug 19, 2007 | 03:47 PM
brrman's Avatar
Default Changed my atf fluid/filter today
Not too big of a deal, about 3 hours work - most of the time was spent removing and putting back the freaking 20-30 bolts that hold the pan in place. Car changes gears WAY better. My car only had 77K miles and it made a huge difference. Lifetime tranny oil that Audi insists is a myth. My car had been slipping on occasion in 3rd gear under hig rpm... now its smooth as silk. BTW, Mobil 1 MERCON V is rated for Audi ZF tranny... which is what I used.
Old Aug 19, 2007 | 05:47 PM
onepoint8tee's Avatar
Default RE: Changed my atf fluid/filter today
Cool. Did you use vag com to check the atf temp as you were filling? I remember doing mine... It was fun.
Old Aug 19, 2007 | 07:26 PM
Redrum1's Avatar
ORIGINAL: brrman
I wrote to mobile and asked about transmission fluid and here's their reply to me...
________________________________
No, Mobil does not have a product that will meet your vehicle requirements.
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL
-Matt Jacob
Old Aug 19, 2007 | 10:40 PM
lboudreau's Avatar
Could you post the instructions on how you did the fluid change. I have a 98 2.8tq and want to change my fluid as well, but the only instructions on audidy.com are for 5 speed 1.8t
Old Aug 20, 2007 | 06:17 AM
david9999's Avatar
Nice. I'm at 188K miles and have done drain and fills twice. When I hit 200, it will be time for pan drop and new filter.
Old Aug 20, 2007 | 06:43 AM
ivey_usmc's Avatar
is the filter there when you take off the pan?
Old Aug 20, 2007 | 07:02 AM
http://www.audipages.com/Tech_Articl...servicing.html For A8, but same concept
http://www.taligentx.com/passat/maintenance/atfchange/ For A4/Passat
Old Aug 20, 2007 | 07:30 AM
lboudreau's Avatar
Thanks man!
Old Aug 20, 2007 | 07:34 AM
ORIGINAL: Redrum1
ORIGINAL: brrman
-Matt Jacob
The 12v has a different type of auto tranny, it might still be a ZF tranny, but its still different, and maybe thats why? IDK.
After reading conflicting stories about what is compatible or equivilent, I just said "**** it" and picked up some oem Pentosin fluidat www.purems.com for pretty cheap.
Old Aug 20, 2007 | 07:44 AM
ironman's Avatar
Nice that is on my list of todo after i get my TB changed, have u tackled a brake bleed yet how was that if so.
