changed pads and rotors... brakes still squeak?
so i changed my rear pads and rotors last friday, it was like i had a paper plates for rotors and potato chip pads... but anywho...
car stops alot nicer now, but it still squeals sometimes? i let off the brake and re-apply and it goes away, but its just kind of frustrating. the fronts were changed 3 weeks before... so i know its not those.. what goin on?
could still be the front ones did you service the bolts that hold the caliper on with copper grease because these are the pistons to allow free movement of the calipers?? also did you clean any rust of the calipers and seat the pads in good, worth a check and ensure the rear dust covers are not touching the rotors
wondering if you guys can help me out with diy brakes...I need to change mine and dont really have the extra money to pay a mechanic to do it...
my ABS and Brake warning lights came on together yesterday... (sorry not tryin to jack your post selfemployed)
Also you can check your local auto parts store I guy recommended a brake spray for lubrication of new brakes..
ORIGINAL: Soley4pres
With the right tools its a breeze. If you're changing the front rotors the bolts for the caliper bracket are TIGHT, power tools or a long extension works well. The ABS light more than likely is your ABS module, or if you're lucky a bad/dirty wheel speed sensor.
http://www.audiworld.com/tech/wheel25.shtml
http://www.audiworld.com/tech/wheel139.shtml
http://www.audiworld.com/tech/wheel2.shtml
