changing oil filter
Old Feb 27, 2005 | 03:58 AM
rnbguy's Avatar
Default changing oil filter
I dont think this post has been made before, but simple question, how do i change an oil filter? where is the damn thing?
thanx :P
Old Feb 27, 2005 | 04:05 AM
aaronamericahall's Avatar
Default RE: changing oil filter
its on the side of the engine it's kinda hard to see and to take off but you will need to get the oil filter wrench at a auto part store to remove it
Old Feb 27, 2005 | 11:04 AM
david9999's Avatar
If you have a tiptronic......
If you think the oil filter is hard to find, don't change your oil until you know which of the drain plugs is the oil and which is the transmission. You have to remove the undercarriage shield to access it. The drain plug you see when you are under your car that is behind the shield is the transmission, and many a newbie has told us.
Old Feb 27, 2005 | 11:18 AM
Jestnomen's Avatar
6th Gear
seriously, if you can't find the oil filter you shouln't be changing your oil. []
Old Feb 27, 2005 | 12:34 PM
Shaunp05's Avatar
Yip I agree with jestnomen
Old Feb 27, 2005 | 01:22 PM
K69camaroz28@aol.com's Avatar
Agreed If you dont have an oil filter wrench get a small screwdriver and a hammer puncuture the oil filter and turn thats the old school way!!!
Old Feb 27, 2005 | 03:29 PM
david9999's Avatar
If you are going to change your own oil, invest in the proper tools and know where everything is supposed to be.
The last thing this guy needs is a stuck oil filter with a hole in it. A 30 dollar oil change is now a 100 dollar flatbed to a garage.
If you can;t get it off with a wrench, than take it into a garage to have the oil changed. The savings in $$$ probably isn't worth the effort.
Old Feb 27, 2005 | 03:36 PM
CRAZYHAWK's Avatar
An oil change with Mobil 1 at WalMart is $29.70, you supply the oil filter. Let them deal with the splash shield.
Old Feb 27, 2005 | 03:48 PM
david9999's Avatar
That is exactly what I do.
Audi02
May 25, 2015 02:51 PM
Kunza
Mar 5, 2012 08:59 PM
Armenian
May 13, 2009 04:04 PM
clim2090
Aug 25, 2008 06:05 PM
mikowen10
May 7, 2007 12:30 AM
