Sponsored by:
Sponsored by:
changing rear brake light on 2003 A4
Old 12-28-2005, 12:35 AM
abcde's Avatar
Default changing rear brake light on 2003 A4
I've done a couple searches on this topic but I'm still unclear how to change the bulb. I know there is a bolt that holds the assembly to the car but the bolt is surrounding by a plastic piece and I wasn't able to get to it. There is also a red pull tab around the bolt and I'm not sure what the does. Does anyhow know how to do this. I miss the days of popping open panels to replace bulbs:0 Thanks
Old 12-28-2005, 12:39 AM
Karl's Avatar
Default RE: changing rear brake light on 2003 A4
HI abcde... that is probably the most un creative handle i have seen in a long time.. unless it stands for somthing cool.. try pulling the red pull tab.. im sure its not the self destruct button for your car (crosses fingers).. you should be fine
shockedimpy
02-02-2008 02:26 AM
smokinA4
02-03-2007 04:20 PM
Boober
11-14-2006 12:28 AM
gmerrill
04-10-2005 06:02 PM
Quick Reply: changing rear brake light on 2003 A4
