Changing right headlight bulbs
Old Oct 22, 2004 | 10:13 PM
urmas's Avatar
Default Changing right headlight bulbs
Did anybody change a headlight bulb on the right side if A4 (2001)? Because of an airflow house (?), it’s impossible to access it from inside as it can be done for the right side... Appreciate your inputs.
thanks
Old Oct 22, 2004 | 10:15 PM
Jestnomen's Avatar
6th Gear
Default RE: Changing right headlight bulbs
the accordian air hose just pops out. Compress the sucker and it will lift out. Then you can access the head light. Then remove the outer cover for the headlight. It'll be obvious when you get to it. The bulb size is a H7.
Old Oct 23, 2004 | 06:23 AM
SlimChriz's Avatar
Yah is easy just pull on the flexy hose thing
poppy
B8 Models
Jan 9, 2010 06:33 PM
babytyson
Jun 12, 2007 05:49 PM
babytyson
Jun 12, 2007 03:29 PM
sdm79
Sep 23, 2006 07:32 PM
mrsnak
Jun 7, 2006 01:40 AM
