check engine light 1st one
Old Jul 26, 2006 | 02:10 AM
Dudek12's Avatar
Default check engine light 1st one
ok so my check engine light came on tonight. When i started the car it sounded like the idle was messed up like it wanted to stall. Dose anyone have any ideas of what could be wrong from the info i gave. thanks alot
Old Jul 26, 2006 | 02:15 AM
Beer Mod's Avatar
Default RE: check engine light 1st one
Vaccuum leak(s)
Old Jul 26, 2006 | 02:16 AM
Dudek12's Avatar
is it ok to start the car to look for them
Old Jul 26, 2006 | 02:24 AM
Beer Mod's Avatar
It's better if you run a leak test w/o the car running so you can hear them. Search 'vac leak test' there should be a write up or two out there it's fairly common it the turbo world.
Old Jul 26, 2006 | 05:29 AM
zat0rsk1's Avatar
Check the connections for your mass airflow sensor. If its all connected and fine then Get the error codes from your car. You might need to get a new MAF.
Old Jul 26, 2006 | 08:44 AM
Beer Mod's Avatar
Good point! Pull some codes first that is very easy.
Old Jul 26, 2006 | 09:36 AM
david9999's Avatar
Go to autozone and have the codes pulled and post them back here.
Old Jul 26, 2006 | 06:20 PM
Dudek12's Avatar
so my car dosnt have any power so i put it on my trailer and took it to autozone and the code is po302 it is cilinder 2 misfire. So iam guessing i need to coil packs, plugs and maybe new injectors. If so would anyone suggest getting 4 all new ones thanks
Old Jul 26, 2006 | 06:35 PM
CRAZYHAWK's Avatar
Try swapping the coil with another to see if the problem moves. If not, do the same with the spark plugs.
Old Jul 26, 2006 | 06:36 PM
techbod's Avatar
a couple of choices here P0302 = misfire detected on cylinder 2 problems could be engine mechanical fault, ignition/fuel system, injector leaking, ECT/MAF sensor, ECM im going for the coil pack
