check engine light
Old Mar 4, 2007 | 10:07 PM
b.hasz's Avatar
Default check engine light
so when your check engine light goes on. what is the first thing you guys look for?
Old Mar 4, 2007 | 10:12 PM
onepoint8tee's Avatar
Default RE: check engine light
autozone
Well, i have vag com to scan for codes, but it sounds like you dont, so go to autozone and theyll scan your ecu for fault codes.
Old Mar 4, 2007 | 10:20 PM
b.hasz's Avatar
oh lol mine did not come one i am just curious as to what you guys look for when yours comes on
Old Mar 4, 2007 | 10:22 PM
x1rider's Avatar
Mine comes on almost daily these days due to the cold weather notgetting along with my high flow catalytic converter. That Vag-Com has paid for itself a long time ago!!!
Old Mar 4, 2007 | 10:27 PM
i look for soemthing that i can hook up to my OBD port so i can see what the fault code is, such as vag com or a obd port scanner.
Old Mar 4, 2007 | 10:49 PM
x1rider's Avatar
I love the Ross-Tech Vag-Com because it allows you to log various parameters while driving the car. When I installed my Awe-Tuning FMIC, I took before and after logs to see the performance difference. After a few 3rd gear runs, I went home and compared before/after IAT, EGT, CF, specified and actual boost, etc... to see if the FMIC made a considerable difference.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
