check engine light code po441
Old May 23, 2006 | 06:35 PM
d_maniac's Avatar
Default check engine light code po441
this code came on last week then i cleared it and now its b ack again, whats causes this code....its something with the evap
Old May 23, 2006 | 06:42 PM
techbod's Avatar
Default RE: check engine light code po441
incorrect flow detected probable causes are hose connections, intake leak, EVAP canister purge valve,
most common cause is the purge valve vacuum pipe and loose/dirty electrical connection
Old May 23, 2006 | 06:44 PM
techbod's Avatar
not to forget the gas cap seal this also causes this problem if it leaks air in
Old May 23, 2006 | 06:49 PM
d_maniac's Avatar
u think this can be the problem with the gas i'm having???
Old May 23, 2006 | 06:51 PM
techbod's Avatar
I doubt it that would have a different effect on the overall performance of the engine and throw spurious codes not just the one
Old May 24, 2006 | 02:59 AM
d_maniac's Avatar
i saw a cracked tube in the engine bay i willl post a pic of it tommarow
Old May 24, 2006 | 10:05 PM
d_maniac's Avatar
could this be the problem???
motomonkey
Jan 13, 2009 06:18 PM
ChitownSLine
Mar 16, 2008 08:00 PM
shkenned
Jul 22, 2007 06:28 PM
SnowSurfns
Jul 9, 2007 11:27 PM
akindy
Jul 2, 2006 04:01 AM
