Check Engine Light Flashing...Car Rumbling!
Old Apr 14, 2007 | 07:22 PM
pec2402's Avatar
Default Check Engine Light Flashing...Car Rumbling!
Looking for some help. While driving today my car started vibrating and rumbling. It was very bad, didn't have much horsepower (maybe i was hesitant) but the check engine light was flashing too. The car is a 2003 A4 1.8T. Haven't had the codes checked, but anyone have a similar problem or have any advice???
Old Apr 14, 2007 | 07:25 PM
techbod's Avatar
Default RE: Check Engine Light Flashing...Car Rumbling!
codes are required as it could be anything, car having no power means its in limp mode
Old Apr 14, 2007 | 07:28 PM
onepoint8tee's Avatar
flashing CEL means you have a misfire. Get your ecu scanned for fault codes (autozone will do it for free). Post up the codes here. But if it says "cyl 1 misfire detected" swap the coil pack on cyl.1 with cyl.2, drive, scan for fault codes. If it now say "cyl2" misfire then you know its a bad coil pack. Which is probably the case.
Old Apr 14, 2007 | 08:33 PM
CRAZYHAWK's Avatar
You shouldn't drive the car with a flashing CEL. +1 ^ , probably
a missfire. Could be spark plugs or an ignition coil.
Old Apr 14, 2007 | 09:20 PM
david9999's Avatar
Same answer
Old Apr 15, 2007 | 01:12 AM
karageorge2's Avatar
or your ignition module if an 03 has one. if an 03 is similar in configuration to a 99.5 as in my case, even though it showed a cyl 2 misfire it was actually the ignition module on top of the air filter that was the root of the problem.
Old Apr 15, 2007 | 01:39 AM
Jorgito's Avatar
last time that same thing happened to my car it ended up in the dealer because of engine sludge,. i hope thats not ur case but its something u should look into. the dealer told me that 90% of the time the sludge builds up on the cam train first. good luck though.
Old Apr 15, 2007 | 04:25 AM
Notahondaowner's Avatar
This just happened to me yesterday, I just replaced all four coil packs to be safe. Total came to 197 bucks after tax from the dealership, if u use the dealership bring ur registration or vin number.I swapped them out and tested the car one by one. Replacing one fixed it for about 1 minute of driving then i had to replace one more. Not sure if 2 of mine went bad or wtf i did, so im leaving all 4 new ones in and testing the old 4 when i get a chance to see which ones are good.
also dealership said not to drive it with misfires because it will ruin your catalytic converter so lace up or find a ride
Old Apr 15, 2007 | 08:29 PM
pec2402's Avatar
Thanks for all the help...i'm just going to drive it half a mile up the road to my mechanic (works on strictly foreign cars) and isn't half as much as the dealer. I don't want to drive it far to check the codes, plus having no car sucks right now so i just want it taken care of. I will keep everyone posted...thanks again.
Old Apr 19, 2007 | 11:37 PM
pec2402's Avatar
Great news, it was only a coil pack! Thanks for all the help and good diagnosis to all. Part only cost $31 plus $30 for labor. Can't believe that small of a part caused the car to run so bad, but now the car runs like new. I just hope it stays this way.
Also, during the absence of the Audi, i was driving an 02' Ford Taurus - if you ever feel you're tired of your car, just drive something like that for a couple of days and you will be thanking God for German engineering.
