check out this k04
Old Jan 8, 2006 | 11:27 PM
juice88's Avatar
Default check out this k04
i found this ko4 on ebay. what do u guys think? how much hp do u think i would be able to pump out alone wihtout chip? even though it needs one.Cheap ko4
Old Jan 8, 2006 | 11:30 PM
juice88's Avatar
Default RE: check out this k04
and would this intercooler setup work? give sufficient airflow? intercooler kit
Old Jan 8, 2006 | 11:38 PM
juice88's Avatar
wait the intercooler only works with stock ko3, i think.
Old Jan 8, 2006 | 11:40 PM
tip5's Avatar
If it flows 700 cfm. Your okay i think with that kit you'll have to mod the piping.
Old Jan 8, 2006 | 11:41 PM
tip5's Avatar
k04 and k03 have the same inlet and outlet so it doesnt matter.
juice88's Avatar
i mean how would it differ from a ko4 from like awe tuning or evoms or something like that?
Old Jan 8, 2006 | 11:46 PM
tip5's Avatar
the intercooler is cheaply made it doesnt flow as much but with a k04 it would work fine cause it doesnt flow at a high cfm all your getting from awe or any other brand is that in itself the name. Just like buying **** from walmart or going to nordstroms same **** but different brand name = higher price.
Old Jan 8, 2006 | 11:50 PM
juice88's Avatar
so deff that turbo, not the intercooler
Old Jan 8, 2006 | 11:54 PM
tip5's Avatar
yep the k04 is a direct bolt on. Nothing else needed other than a fpr, spark plugs, software, and a oil change to be running good.
Old Jan 9, 2006 | 12:12 AM
juice88's Avatar
sorry fpr? i thought injectors are needed?
